Ride height adjustments (rake?)
Old Aug 6, 2014 | 09:04 AM
Apex1.0's Avatar
Default Ride height adjustments (rake?)
So I am prepping the S for my next track day. My car is almost 100% stock. I added a set of H&R sport springs because I wanted a small drop and I already had them. Even without an alignment there is a definite improvement over stock. The ride is good, plus there is more pitch and roll resistance. It is not overally bouncy, the shocks are doing a good job.
My issue is the ride height and the rake. The car always had some rake to it, now it is more extreme. These are some of the most mild springs you can get and right now the front jacking pads are 3 5/8" off the ground. The rear pad is about 4 3/4. So over an inch difference. I need to balance it out and raise the front. Can I use a small spacer in the front to raise it? Is there another way to change ride height, even slightly? What should the rake be?
RavynX
Nov 29, 2011 10:15 PM
nearwater4me
Feb 6, 2008 08:29 AM
doctornick
Mar 30, 2007 05:20 PM
Mok
Dec 11, 2003 08:43 PM
