Ride height discussion
What about lower ride heights in general, has anyone tested if there is a significant benefit from dropping the cg by going really low...say 13" to 12.5" to 12.25" etc?
I've never played with rake, I've always run flat to no more than 1/4 inch higher in the rear so I can't comment on it.
It seems that going lower than 1 inch lower than stock ride height causes issues with suspension geometry and bump stops. The bump stops are different on different shocks/coil overs and of course spring stiffness plays a part. I personally don't know of any fast track S2000 lower than about 1 1/4 inch (East Coast S2000s). In general, the stiffer the suspension the lower you can run so the West Coast guys may run a little lower out there.
josh7owens and oinojo , may I know your alignment/wheel setup and any aero?
Would like to do a comparison.
I'm not really anyone but since you asked heres my set-up (autox STR)
wheels are 17x9 +62 with 255 kooks all the way around.
Front
Gendron 1.25" solid bar with ball bearing mounts 6/6
camber -2.9
caster 6.5
toe- 0
12.5" ride height
900 lbs springs
Rebound 6/14
HS compression 10/14
LS compression 3/5
Rear
Gendron rear bar with ball bearing mounts 3/5
camber -2.5
toe in .29 each side (1/4" total)
12.5 inch ride height
800 lbs springs
Rebound 9/14
LS compression 3/5
Heres is what my car looks like at 12.5" ride height...
you can look here for shock dynos and get a idea of what my shock settings are force wise...
https://www.s2ki.com/s2000/topic/818.../page__st__200
Also curious to see his set-up... hopefully he will post it up as detailed as mine
Front
camber -2.9
caster 6.5
toe- 0
12.5" ride height
900 lbs springs
Rebound 6/14
LS compression 3/5
Rear
camber -2.5
800 lbs springs
Rebound 9/14
LS compression 3/5
I guess I just wanted to point out that it is certainly possible to run your car very low and have it be fast. That said, I don't know that running the exact same setup would give the same results for everyone, there are too many variables. Each person will have to tune their setup for themselves.
For example, the following specifics will all significantly affect what setup you need for your car:
-Driving styles vary dramatically person-to-person
-Damping differences
-Different tracks (autocross vs road course, bumpy vs smooth, low speed vs high speed corners)
-Amount of downforce from the rear wing
-Weight distribution in the car (for example rear weight bias)
-Chassis torsional rigidity (for example caged vs not caged)
-Tire choices
-more...
-Tire choices
-more...
I'm pretty sure Josh has 3-way JRZs and Speed has AST4100s (He has Aaron Leitchy's old car).
I've kept up with Josh's STR build thread and I'm pretty sure his JRZs have been shortened a good bit to allow for a low ride height.
I had talked to Aaron for a little while on the phone with a lot of questions about his AST setup and they are the normal length shocks (they actually have about 1/8" less travel than KWs at the same height) yet he ran the car very low and didn't seem to have any problems. I actually just picked up a set of AST 4100s myself and plan on running them at a very similar ride height.
What steve said ^^^ I have some billy badass triple adjustable JRZ Motorsport series shocks. the fronts had tons of travel to start with but I had to pay big bucks to shorten the rears 1.25" over where they started. From the clevis (sp?) hole to the top of the dust cap is 10.75". My bump stops are very very tiny, they are made to fit inside of the cup on the bottom of the top hat. So I prolly have around 3" of rear travel. So more then enough even at my super low ride height.
If I didn't run so low I prolly wouldn't run as stiff of springs but since the "messed up" roll center causes more body roll at my height the car requires more spring to control this roll.
I have a "build thread" that's on the fist page of the racing forum. The thread started as just a thread about my shocks but a few weeks ago I changed it to a build thread and started posting more stuff to share with everyone.
With my new adjustable rear bar I'm able to crank back up my front bar without causing push. This makes me very happy because my driving style likes a big bar. I like to be agressive with the wheel similar to Matt's driving style if you watch his videos. The big front bar allows me to throw the car in without upsetting it.
As for Aaron and the ASTs I'm a fan. He talks very highly about them and since I've seen his car in person many times at his shop it's very low. I would say as low as my car. I need to get to Aaron in a few weeks for some corner balancing.
