Road Race & S2000
Took my car to the track yesterday. It was a lot of fun. S2000 is quite the car for the money, although it left me wishing for more power and better brakes (my other car is a Supra Turbo).
I have noticed that under certain conditions the car would burn some oil - a puff of smoke from exhaust. Is this a common occurence? Is this a problem? Is there a fix? Both mine and my friend's MY '02 had this occur under heavy cornering (turning right) in 2nd gear at about 7,500-8,000 RPM.
Also what is the recommended maintenance after a track day. I was going to change rear diff fluid, engine oil, and brake fluid. Any additional maintenance? What kind of differential fluid is recommended? Redline Synthetic? Honda OEM?
Thanks,
KGB
Thanks,
KGB
Originally posted by pellisS2k
Brake fluid and better pads are recommended for track duty (and should address your comcerns of the OEM brake setup).
Pellis - I ran ATE blue & Carbontech P+. It's a good combo - the brakes held up good fade-wise. Don't get me wrong, OEM brakes are OK - they just not Super
.KGB
1. To improve brake cooling, remove dust shields. Braided lines will help with pedal feel as well. Ate fluid and P+ pads are my favorite combo.
2. Smoke puffs, particularly on hard right handers, is normal in many cars. I'm one of the lucky few that doesn't smoke on track corners.
3. Redline 75W/90 or Mobil 1 75W/90 synthetics is a good choice for the rear diff.
Originally posted by Rich 4 S2000
better brakes?... The S2000 matches ferrari in the braking side of things?
rich 4 S2000 - there is always room for better. Trust me if you ever take S2k to the track that's hard on brakes you'll want better.
kgb
Unless your getting Fade the only way to brake better is to have more GRIP. So you need better tires. Alot of people think that Better pads or larger rotors will actually shorten their stomping distance. If you can activate the ABS all the way down then your limiting factor is your TIRES.
