Running 17x9 square with no aero
As mentioned, bigger front bar for sure. I ran square with a stock suspension plus a bigger front bar, rear still hooked, and the result was close to neutral steer. It would still oversteer at the limit, but very progressive and controllable. Car had very nice rotation at corner entry as well.
If you did what I did, you'll run the rear softer, then the front stiffer, then disconnect the rear bar, then install a smaller rear bar, then consider higher rates.. only to understand perhaps you should have probably gone with a larger more adjustable front bar at the beginning.
You won't get too much oversteer the car will just be closer to being neutral. The transition to oversteer will also be much more predictable and controllable. Especially after moving to something like the DFV.
Test before you go changing stuff or you won't actually know the differences. If you are planning to do square setup on stock suspension. Don't would be my recommendation, just learn to drive the car faster as is.
