schroth harness
I recently purchased a Schroth autocontrol harness from WebDiva. my question is where does everyone mount the inertia reel in the S2000? I cant find anything using the search.
thanks alot,
Ryan
thanks alot,
Ryan
Originally Posted by mikegarrison,May 27 2007, 09:35 PM
Ever consider that maybe you should have had an answer for that before buying the harness? I doubt if there is any good place.
Im trying to see how others have done theres. If no ones else has used this harness before, Ill mount it on my roll bar when I have it made next month. or use it in my fit for autoX.
2) If you are having a roll bar installed to your car, you should have mentioned it before. That is the correct place to mount any sort of harness.
3) You didn't say, but I certainly hope you are not using this with the stock seats. It would not be safe.
1. I figured not many would have this particular harness but a couple people might have it.
2. That wasn't my question. How others have done there's is my question. Being its a different harness I was curious how and if people got creative to mount it.
3. see sig (buddy club)
I really do appreciate your help. if there's no one who has mounted these before ill post back when I'm finished. Hopefully it could help someone else later on who would like to install a similar harness.
Originally Posted by krazik,May 28 2007, 06:14 PM
then you should wait to install a proper harness. You don't value your head?
If not, you're asking in the wrong forum until then.
proper harness? value you my head? whats not proper about a scroth harness? the harness is not installed and will not be untill have a roll bar.
my question was not "How can I?" but "How have other people mounted theres?" being that very few have, if any. Ill figure it out myself.
again if this isnt in the right forum could a mod move it to the right forum.
Thanks for you help guys
umm maybe I missed something here but the Schroth harness DOES NOT need to be used in conjunction with a roll bar. It allows you to move back and forth just like the OEM seat belt.
You might have to fabricate some kind of bracket for the inertia reel though. I have one and do not know any location for it.
