Setting Camber Based on Tire Temps
Old Sep 26, 2011 | 05:09 PM
turbo8765's Avatar
Default Setting Camber Based on Tire Temps
If you're running the "ideal" amount of camber for your setup, should there be any temperature gradient across the tire from inside to outside?
At Roebling this weekend my outside edge was up to ~38 degrees hotter than the inside edge. I could obviously benefit from more camber, I knew that before I checked temps.
Are even temps inside to outside the goal? Is say a 5-10 degree gradient a reasonable compromise?
Old Sep 26, 2011 | 08:25 PM
WynnS123's Avatar
Your inside temps should be around 20% hotter than the outside because the tire spends more time on the straights than the corners. Naturally, the inside will retain more heat than the outside section of the tire.
Old Sep 27, 2011 | 01:54 PM
turbo8765's Avatar
How did you come by the 20% number? Seems like that would be too hot on the inside edge.
I was at roebling this past weekend, and I'm pretty sure I spend more time with the wheel turned than straight. I can review video to confirm.
Furthermore, the amount of heat generated per unit of time under cornering would be much greater for the front tires than on the straight.
Old Sep 27, 2011 | 04:31 PM
bronxbomber252's Avatar
Yes, but consider this, accel, braking and anything in a straight line heats the inside... also turning heats the inside of the inside tires. I agree that 20% sounds too high, im thinking more like 5-10%
Old Sep 27, 2011 | 07:11 PM
Dipstick's Avatar
Check this article...
http://www.northstarmotorsports.com/tech.tips2
Old Sep 28, 2011 | 08:33 AM
ZDan's Avatar
Yup, hotter on the inside by xx degrees. %age temperature is meaningless on a non-absolute scale!
Consider that while cornering with optimized camber for cornering, you should be heating the tire evenly, while on the straights you'll be heating the inside. Also, speed in and of itself, aside from braking, accelerating, and cornering puts heat in the tires, and when you're going fastest, inputting the most heat, you're in a straight line.
Old Sep 29, 2011 | 05:50 AM
turbo8765's Avatar
Originally Posted by Dipstick
Thanks for the link.
From the article... "If the outside temperature is consistently hotter (by more than 10 F) than the inside, try dialing in a bit more negative camber."
Therefore if the inside edge is no more than 10 degrees COOLER than the outside...
boyguan
Apr 23, 2013 11:53 PM
WarrenW
Sep 1, 2010 01:22 PM
gfacter
May 19, 2006 11:03 AM
ukfinance2002
May 25, 2004 05:54 AM
Mack
Jun 25, 2001 06:41 PM
