Setting up more agressive alignment for the track
Old Jan 30, 2014 | 06:50 AM
iamxpl's Avatar
Originally Posted by boyguan
My caster is maxed at 5.7. Not sure why
your compliance bushings maybe done for. or was 5.7 your personal max? it should be able to get up to 7. if your bushing isnt seized or destroyed then it might be something within your suspension.
Old Jan 30, 2014 | 10:19 AM
boyguan's Avatar
I changed to new power flex compliance bushings. One side can get like 3 camber other side only 2.5 camber. I think I'll have the alignment shop next time try to move my sub frame
Old Jan 30, 2014 | 10:32 AM
iamxpl's Avatar
you can easily check that yourself, there is an alignment window on the subframe.
Old Jan 30, 2014 | 01:39 PM
sweetdill's Avatar
Originally Posted by Thateguhate
Originally Posted by sweetdill' timestamp='1391063105' post='22990210
Front Caster 6.5 (I wonder if +caster contributes to wishy washy steering center feel)
Front Camber -3.0 (with solid/hardened bushings -.25 more without)
Rear Camber - 2.75 (with solid/hardened bushings -.25 more without)
Front Toe 0
Rear Toe 1/8
I'm really glad that I asked you guys before making my appointment. How does your car react with those current settings? and what was it like before?
Originally Posted by qbz
If you have semi race tires they often recommend -2 or more camber. The manufacturer of the tires you buy usually have specific recommendations for there tires. Also by running 225 in front and 255 in the back will give you understeer under hard cornering try to have the same wide all around.
Sent from my GT-I9300 using Tapatalk
hmmm interesting. It could probably be done considering I'm raising the car now. I thought about it but I had felt so content with the 225's I didn't really consider it much. As of now, the oversteer really hasn't been bad.. Right now I have the old Starspecs in the front and RS3's in the rear.
My car is super fun to drive. I love it. It also wears the tires nice and flat, biased to the inside only a tad.
Bears noting that I have Eibach R2's 800f 700r, stock sway bars, RCA's at all four corners, and front bumpsteer steering rack spacers with 255's square, big wing and splitter.
I had to dial back the caster from over 7.
Old Jan 30, 2014 | 01:57 PM
Thateguhate's Avatar
Nice I see. Ok I'll have to discuss the variables with the techs at the place I'm going to and see what they say. Thanks for the feedback.
Old Jan 31, 2014 | 02:48 PM
andrewhake's Avatar
You need to list more info on your suspension setup to get good suggestions for alignment.
Old Jan 31, 2014 | 07:14 PM
I would have posted up my current alignment settings but I misplaced the sheet. It's relatively simple though, I didn't see the point in modding too much without having the skill compensate for it so I just have the bare essentials.
Tires : Dunlop Starspecs on the front and RS3's on the back
Suspension: Koni Yellow's / Ground Control's 550f/550r
Sway bars: stock
No bumpsteer kit
Old Feb 6, 2014 | 08:31 AM
suterusu's Avatar
Increased caster increases on center steering feel or steering re-centering force.
It also increases negative camber as steering angle is added.
Old Feb 6, 2014 | 09:22 AM
Sebring AP1's Avatar
Front Toe 0
Rear Toe 1/8
This is what you want. You also want a BSK.
Also why are you running two brand of tire on different ends?
Old Feb 6, 2014 | 10:05 AM
ndogg's Avatar
BSK are over-hyped around here. If you look at any toe graphs you will see that lowering this car an inch has absolutely no effect on bump steer. Granted the AP1 has a decent amount of bump steer in stock form, but it is manageable.
