simple question for the wise
Old Dec 3, 2001 | 05:47 PM
jschmidt's Avatar
All of these reasons are good but there is another.
Should you (while spinning and probably in a panic) miss the brake and slam the gas, pushing in the clutch disconnects the drivetrain and prevents doing exactly the wrong thing. Better to hit the rev limiter than hit the wall.
Old Dec 3, 2001 | 06:58 PM
Mike Schuster's Avatar
On the track I think "when in a spin, both feet in" is the way to go. Especially in a race with cars darting this way and that trying to get around you. You don't want to be jumping out in front of them unexpectedly when your car hooks up with the brake released as it is slowing down to a stop.
But I'm worried about recommending this to people who don't have track experience for driving on the street. The spin probably is going to happen rarely, and you don't want the person thinking "what do I do, what do I do?" in this situation. Just slam on the brakes, which is what you would do naturally, in a bad situation. I think this proper response. Forget about complications, expecially if you are not going to be practicing them reasonably often.
So what if you stall the engine? Just that will not hurt the car.
Old Dec 4, 2001 | 07:02 AM
s2ktaxi's Avatar
The both feet in guideline is mainly for race cars that do not have ABS. The idea is that the car will at least predictably continue to slide in the direction/trajectory it started with (which may be good or bad) but at least for cars around you - it is consistent. But with cars with ABS, then the only reasons really is to diengage the drivetrain.
Old Dec 4, 2001 | 11:28 AM
Penforhire's Avatar
Another benefit to both feet in has to do with stuck accelerators. Sure you may blow the engine but better that than adding 240 HP (or whatever your race car has at rev limit) against your braking.
Old Dec 4, 2001 | 02:12 PM
2kturkey's Avatar
[QUOTE]Originally posted by DaRKCrow
[B]Well,
Old Dec 4, 2001 | 06:21 PM
calc's Avatar
DaRKCrow ends his (relatively) long silence with a puzzling, if not bizarre, comment.
Are you lost in a thread of confusing allusions, DaRKCrow?
cal
Old Dec 18, 2001 | 02:26 PM
flippos2k's Avatar
[QUOTE]Originally posted by originale
[B]thanks a lot.
quickshifting
Aug 23, 2007 11:17 AM
USMC2006s2k
Dec 6, 2006 06:17 PM
MistaSnipes
Jun 19, 2004 02:59 PM
jlstyle82
Oct 9, 2003 09:11 AM
Dliodoir
Dec 11, 2000 07:34 AM
