anyone? - bueler.?
I use a web translator to try to understand Japanese websites so no guarantees. It looks to me that Honda claims the wheels to be stronger and lighter than stock and quotes 8kg or maybe less than (I
FWIW, someone posted awhile back that they weighed the stock wheel and tire combo at 25 lbs. If true, I couldn't see much of a weight advantage with the BBS wheels.
the stock wheels weights are ~17.8/18.8 lbs, front and rear respectivly.
Looks like a marginal improvement over the stock ones. Someone on the email list maintains that they are .5" wider front and rear, but I'm not sure. Can anyone call over there and verify the size and weight?
Found these pictures from a Japanese site:
These are the front wheels stock vs BBS: http://www.try-net.or.jp/%7Emiyu/s20...el/s02_e_f.jpg http://www.try-net.or.jp/%7Emiyu/s20...el/711_b_f.jpg Rears: http://www.try-net.or.jp/%7Emiyu/s20...el/s02_e_r.jpg http://www.try-net.or.jp/%7Emiyu/s20...el/711_b_r.jpg Scales appear to be in lbs. |
Originally posted by mt2000: Found these pictures from a Japanese site: These are the front wheels stock vs BBS: Scales appear to be in lbs. |
Oops - yup, you're right.
Good find with the wheels on the scale. Means a 2.2 lb savings on each front and a 3.3 lb savings on each rear. The wheels are said to be stronger but the same widths as the stock wheels.
cdelena:
So how much do the stock wheels/tires weigh? These BBS figures are heavier than the reported 25 lb weight I've seen for the stock sets. Although I've never weighed the stock wheels / tires myself. Conversion of above figures, 1 kilo = 2.2 lbs 19.5kg = 42.9 lbs 18.5kg = 40.7 lbs 20.5kg = 45.1 lbs 19 kg = 41.8 lbs |
