spark plugs? how often replace?
Old Feb 28, 2017 | 04:53 PM
S2000_916's Avatar
Originally Posted by jyeung528
might wanna recalibrate your feel and see if you're actually getting it to 22 ft/lbs.
also, depending on which plugs you use, on initial install there might be specific install instructions such as 3/4 turn after contact or something like that.
i suspect feel is the culprit here, plugs shouldn't be backing out.
yeah I did use a torque wrench the first year I went to the track but it just felt too lose so I hand torqued them down. I bet this was back when they recommend 18fts . thanks for the info!
Originally Posted by cosmomiller
Me too.
Billman recommends 22 ft/lbs. He had a spare head and ran a test to see how far he could torque a plug before failure. As I recall he went to 70-80 ft/lbs before the plug failed. The threads were still intact.
All kinds of problems rise to the surface from loose plugs. Just torque them down right the first time. Don't use anti-sieze on NGK plugs. They have a coating called trivalent plating. This silver-or-chrome colored finish on the threads is designed to provide corrosion resistance against moisture and chemicals. The coating also acts as a release agent during spark plug removal.
thanks a lot of good info!
Originally Posted by freq
I have my elbow calibrated yearly too.
haha
Originally Posted by s2000sccaracer
Since this is the Racing and Competition forum, change them at least at the beginning of the race season, whether or not they need it. For everything else that you are spending on a "race" car, spark plugs are relatively inexpensive.
icic good idea
Old Feb 28, 2017 | 05:39 PM
ajohnson's Avatar
I change once a year or twice depending on number of events. I never wait for a misfire as that's going to cost me. Like other change at the beginning of the year and then I will put a new set in for the runoffs.
Im a pack rat. I don't know how many perfectly usable spark plugs I have around but it's always some piece of mind.
turbo_pwr
Sep 7, 2009 07:47 AM
neoarroyo
May 29, 2007 09:02 AM
aaron0601
Jan 22, 2007 05:44 PM
dmw16
Jan 16, 2007 06:34 AM
S2K_Ownz
Apr 26, 2003 05:49 AM
