Spring rate recommendations for my setup
R&Cers - I'd appreciate your recommendations on spring rates for my setup and intended use.
Dampers: new Koni Sports, single adjustable
Spring brand: TBD but most likely GC
Year:2003
Use: 90% track 10% getting to the track, HPDE and TT
Compliance desired: Only enough to keep the tires in contact with the track
Tires: RA1 or NT01 Current, 235/255 Future, 255 all around
Aero: Current, Hardtop Future, Hardtop and APR GTC-200
Camber: SPC ball joint camber thingy
Track surface: East cost tracks, kinda bumpy
Sway bar: Whiteline front bar, non adjustable
The recommended GC kit for track use on an S2000 is 380/340 or something. I'd prefer to go with a higher rate (up to the max for a stock Koni Sport) but wanted some guidance.
Thanks
Year:2003
Thanks
[QUOTE=dc_s2k,Jul 2 2010, 06:44 AM] R&Cers - I'd appreciate your recommendations on spring rates for my setup and intended use.
Year:2003
Year:2003
Get the highest rate those dampers are rated for!
I'm on KW Clubsports at 570lb/in and they're still relatively soft for track use. I think many of the road course guys are in the mid-600 range. Auto-x guys are in the 800 range on the fronts, 700 on the rear.
Originally Posted by dc_s2k,Jul 2 2010, 08:30 AM
That's one of the things I want to know, as I don't know the highest spring rate for Koni Sports. I have "heard" 500 but Tubedriver's suggestion seems to indicate 450.
thanks for your replies. I'll call Koni and post up any info I get.
Are any of you running a functional wing with 400# rear springs? It seems that the downforce may necessitate a higher spring rate.
Pure track cars start in the 900lb range and go up from there.
I used 900/950, and I've seen others use as high as 1200. I would think about 750 is the bare minimum for a dedicated track car.
500 is really light. (The Koni's are going to be the weak spot here as they are valved for really light springs).
