Spring rates
Originally Posted by Thnks2u,Mar 7 2005, 02:22 AM
A few months back I took a set of MY 04 OEM springs to Turner Motorsports in MA and had them measure the spring rates with their equipment. Two days and $85 later gave me a printout 5 measurements made on each spring.
Fr(Ave) = 250lbs/in +/-5%
Re(Ave) = 255lbs/in +/-5%
These numbers pretty much agree with the known values for the 00-01MY and the "percent changes" that can be found in the literature.
Cal
Cal
Also, if they rated them, they should have the exact rate, not "+/-5%".
Ryan
So, assuming the 250front/255rear is correct, that would mean we have the following versions of S2000 springs?
'00-'01 (Based on info from King's website, no longer available.)
218 / 291
'02-'03 (Calculated from '04 numbers.)
233 / 283
'04-'05 (Based on Turner Motorsports measurements.)
250 / 255
vtecvoodoo, sound like Thnks2u does have the exact measurements - he stated he has a printout of five readings from each spring. I suspect he just summed it all up for us, perhaps.
Anyway, given my experiences of driving each of the three different configurations, that tends to agree with my impressions - although the different sway bar rates would have to be taken into account as well.
218 / 291
233 / 283
250 / 255
Originally Posted by hondamanwill,Mar 6 2005, 06:22 PM
I understand what your saying but in order to stay in my stock class I have to use factory springs.
The springs rates for '02-03 on the original post were wrong. '03 rear springs are DEFINITELY stiffer than '00 rear springs.
'02-03 spring rates should be
230F/300R
Check out my post here for details.
230F/300R
Originally Posted by rlaifatt,Feb 21 2005, 02:47 PM
I've tried these different springs on my JRZ's:
Front/Rear:
425/550
500/550
500/650
550/650
550/750
650/750 and probably a few other permutations
You can definitely feel the difference in ride and handling, but this probably varies (greater?) depending on the shocks too.
Front/Rear:
425/550
500/550
500/650
550/650
550/750
Originally Posted by stocky,Feb 21 2005, 12:30 PM
Strang etaht Mugen has such a difference between front and rear rates.
Also the go the inverse way than SPOON ?!
Could it be that the spring rates don't affect the ride THAT much than we think?!
Also keep in mind that Spoon designed their system to work with smaller diameter (and wall thickness) sway bars. The front is much smaller (as a percentage) than the rear sawybar change (in reference to 00-01, when they were designed), while the Mugen uses larger diameter swaybars on the front, and I believe the rear is unchanged, but I am not a Mugen expert, so don't quote me.
This is my theory anyway. But what do I know?
Again, sorry for going off topic.
cheers
W.
PS. Richard...how about a few springs for your old pal?
I have the 2 pairs of 400# from the JRZ's I bought from you. I also have a pair of 450's and a pair of 800's.
If I can get a pair of 550'ish and a pair of 650'ish, I won't need a pair of the 400's.
<edited>
