SRS by pass
Old Jun 14, 2010 | 07:48 AM
akira2019's Avatar
Default SRS by pass
Hi,
I want to install a racing seat + a racing harness.
I want to remove the driver retractor seat belt device.
I also want to remove the passenger airbag.
- Can you please tell me if I need to plug a by pass resistance for the driver seat belt tensioner connectors? How many ohms ?
- Same question for the driver seat belt switch connecor located under the driver seat (the one connected to the buckle in order to identify whether or not the seatbelt is latched).
- Same question for the passenger AB.
Thanks.
Old Jun 14, 2010 | 08:41 AM
dan_uk's Avatar
do you just not want the SRS light on because thats all that happens when you start pulling bits of it out
Old Jun 14, 2010 | 10:01 AM
Izze-Engineering's Avatar
Banned
See my post from the weight reduction thread:
https://www.s2ki.com/forums/index.php?showt...post&p=18399003
As for the airbags, measure the resistance across the airbag terminals and then use an appropriate resistor, should work.
Old Jun 14, 2010 | 11:38 AM
urBan_dK's Avatar
2 ohms should do the trick.
Old Jun 14, 2010 | 11:16 PM
akira2019's Avatar
thanks.
I just want to avoid the red light on the cluster... and the seat belt reminder buzzer to be off !
youngturk
Nov 27, 2017 07:20 AM
badboy00z
Jan 18, 2011 08:47 AM
an2ny
Apr 3, 2010 06:20 AM
JstnRyan
Aug 4, 2008 02:31 PM
BlueS2000Boy
Jan 8, 2004 08:24 PM
