Originally Posted by HammerBro129
(Post 24499340)
Originally Posted by Ricky_Flowers_
(Post 24499466)
Oh wow, that's pricey. I thought for some reason they were in the $1950 range.
https://www.s2ki.com/forums/sponsor-...-kits-1186234/ |
Originally Posted by DanielB
(Post 24499346)
The front BBK shifts the brake bias forward 13%. That's not an insignificant amount.
(Post 24499517)
I'm pretty sure that is not correct. You may want to call them and ask but I think at most 2%.
Putting it all together (math is in the spreadsheet), the C43 BBK generates 7% more brake torque than the ST40 and 12% more than stock. Again the math is all in the spreadsheet - if there's a mistake I'm happy to correct it, but I think it's accurate. It's pretty basic physics. |
What spreadsheet? Show me your math. The pad annulus is 40mm. I would just call them and ask because it't not always that basic believe it or not. They are very helpful.
(Post 24499619)
https://docs.google.com/spreadsheets...it?usp=sharing With all due respect to Stoptech, their numbers should be close to the math - if not, then something is not right. Sometimes the information gets altered as it transfers from engineers to marketing people. I've had that happen far too often in my professional life to just accept numbers when they don't align with basic math and physics. Again, if you don't mind, please review the math in my spreadsheet and if there's an error, I'm happy to fix it. FYI, I'll leave it to others to call if they choose. I already have a BBK :) |
Hymm not sure. I think your math is correct but like I said I am willing to bet there are other factors as they are designed to work with OE rears and not throw off the balance. They did tell me that the force point isn't always assumed to be at the center of the pad. Looking at the sheet though I am pretty certain the Spoon's piston size is off. I measure mine at about 36 & 40mm.
Thanks, Brook |
Just out of curiosity, why is this limited to 00-05. What is different about the 06+ that these will not work?
(Post 24499645)
Thanks, Brook Changing the piston diameter to 36 and 40 makes a significant difference: the front bias drops to 7% which is 2 percentage points more than the ST40 kit. So that's probably the issue - the website data is inaccurate. |
Originally Posted by Jub
(Post 24499660)
