STR CR or BSP AP1 shell (engine swapped)
With the boom in BSP recently I think this is a good topic to discuss, end result for each car cost about the same.
Pros and Cons, I'm interested in what everyone says.
-Marc
Quick off the top of my head I came up with....
STR CR
Pros
- Better resale value
- Tires are cheaper
- Won’t break as many parts
- Easily driven to and from events
Cons
- Slower!!!!!!
- Doesn’t push you as a driver as much as a BSP car would
BSP AP1 (2.2 Engine swap)
Pros
- Faster, 1.5 seconds on a 60 second course (theoretically)
- Lighter
- More power
- More RAW race car “like”
- Pushes you as a driver, Likely to be a faster car then you are a driver for a while
- Win more Raw Time trophies (If your club does that)
- More WOW factor, adrenaline rush!
- May be a cheaper build!
Cons
- Break more parts
- Bad resale value if ever sold
- Tires are 3 times the cost and last 1/3 as long
- Need to trailer car or atleast use a tire trailer
- Could be SoL if you broke the car without a trailer on-site
STR CR
Pros
- Tires are cheaper
Cons
- Slower!!!!!!
Pros
- Lighter
- More power
Cons
- Break more parts
What!? That's crazy. That's like saying stock class doesn't push a driver as much as a SM driver. If anything I'd argue the less prep you can do to a car the more the driver part of the equation matters and the more you have to push.
I feel its much harder to drive a faster car fast. If you were to take "fully prepped for the class" cars from each category, you would be more consistent with the slower cars and less consistent with the fast car. I have proven this theory with myself, but feel this would apply for most drivers. R-Compounds certainly help mask mistakes. STR was much harder for me than B-Stock because of less overall grip with the street tires. I predict that BSP will be harder than B-Stock, but not sure how it will compare to driving an STR car. I also strengthened my driving skills with my experience in STR. Hopefully I will continue to grow in BSP! Either way, the competition we had in STR will be difficult to duplicate...
-Marc
-Marc
