STR Prep - ECU and Tuning Discusson
=============== STR Threads ===============
STR Prep - Suspension and Alignment STR Prep - Shock / Damper and Springs Discussion STR Prep - Differential Discussion STR Prep - ECU and Tuning Discusson STR Prep - Wheels and Tires STR Prep - Exhuast (tip to tail) STR Prep - Weight Reduction STR Prep - Sway Bars SCCA Solo - STR Rules Discussion ---> (Debate rules and proposals here...) STR Prep - AP1 vs AP2v1 vs AP2v2 vs CR STR Prep - Intake • from DIY to Mugen STR Engine Mounts =============== STR Threads =============== Post your tuning mods and approaches. Dyno plots? Basic engine setup to go along with the tuning? Here is a good read that introduces all the basic concepts toward understand tuning. Search google for a PDF using the words "AEM EFI Basics" ================================================== August 11, 2012 - Here is a link to the most complete setup description within this topic. Post #580 - GReddy EMU Setup by Brian Karwan of Karcepts January 2012 - link to my installation and setup for the GReddy EMU. Post #329 - GReddy EMU install and setup ================================================== Car: 2003 S2000 AP1 ECU: Stock Tuning Method: GReddy Emanage Ultimate and Boomslang Harness Dyno: Hub mounted Dyna Pack Tuner: Tony at UMS Tuning, Tempe, AZ Header: PLM CAT: Berk like homemade HFC 200 cell/sq-in CAT Back:OEM cut at Y with down pipe Intake: K&N FIPK Below is the result of tuning. All relavent information added as notes on the plot. See second plot for comparison with twin loop muffler installed. Reasonable gains after bolt in mods. I wish I had a baseline before mods to see the overall gains from stock. Ran an event yesterday and the increased torque made a difference for second gear pulling out of turns. http://random1photo.zenfolio.com/img.../p19019553.jpg With muffler installed. Only small losses with this 93 dB compliant muffler which saves 9.5 lbs when removed. http://random1photo.zenfolio.com/img...p536218064.jpg Twin loop muffler shown below. See STR exhaust thread post #74 for more detail on this exhaust mod. http://random1photo.zenfolio.com/img...p146097309.png http://random1photo.zenfolio.com/img...95850115-4.jpg Additional information for Greddy Emanage Ultimate... Emanage 101 August 11, 2012 - Here is a link to the most complete setup description within this topic. Post #580 - GReddy EMU Setup by Brian Karwan of Karcepts |
Hypertech tuner bumps rev limiter up 500rpm and lowers VTEC engagement 500rpm.Cheap seems to work fine,has a soft rev limiter so you can hold max revs.
I suppose this will be more settled later this week when Fastrack comes out and (presumably) includes the 2012 ECU rules.
Car: 2001 S2000 AP1
ECU: Stock Tuning Method: APEXi VAFC (just installed 10/18/2011) and Boomslang Harness - VTEC dropped to 5K RPMs Header: Toda Torquie-kun INTAKE:K&N FIPK CAT: Berk 2.5" CAT Back: Invidia with OEM resonator right after the cat -Dave |
Car: 2000 S2000 AP1
ECU: Stock Tuning Method: APEXi NEO and Boomslang Harness Dyno: no digital graph, sorry Header: toda torqie-kun CAT: Berk 70mm HFC CAT Back:T1R 70r INTAKE:K&N FIPK Drops the vtec to 5k and gives a smooth vtec transition and some mid-rang. The issue with the NEO is you can only take out fuel, not add. Hopefully a rule change is in the making. |
Fastrack is out:
http://www.scca.com:8080/assets/11-fastrack-nov.pdf Remove the Appendix F clarification under Street Touring titled “Emissions System”. Change 14.10.F to read as follows: “F. The engine management system parameters and operation may be modified only via the methods listed below. These allowances also apply to forced induction cars, except that no changes to standard boost levels, intercoolers, or boost controls are permitted. Boost changes indirectly resulting from allowed modifications are permissible, but directly altering or modifying the boost or turbo controls, either mechanically or electronically, is strictly prohibited. Traction control parameters may not be altered. Any standard OBD communications port functionality must remain. Check Engine Lights (CEL) may be disabled via software. Alternate software maps which violate these restrictions may not be present during competition, regardless of activation. 1. Reprogrammed ECU (via hardware and/or software) may be used in the standard housing 2. Supplementary (“Piggyback”) ECU may be used subject to the following restrictions: a) Connects between the standard ECU and its wiring harness only. b) Must be plug-compatible with the standard ECU (no splices). 3. Electronic components may be installed in-line between an engine’s sensors and ECU. These components may alter the signal coming from the sensor in order to affect the ECU’s operation of the engine management system. Example: fuel controllers that modify the signal coming from an airflow sensor. 4. Fuel pressure regulators may be replaced in lieu of electronic alterations to fuel system parameters. It is not permitted to electronically modify the fuel system AND replace a fuel pressure regulator. 5. Ignition timing may be set at any point on factory adjustable distributor ignition systems. 6. VTEC controllers and other devices may be used which alter the timing of factory standard electronic variable valve timing systems.” What does this mean for those of us with pre-06 cars? |
So a plug and play piggyback haltech fits the bill.
Originally Posted by murderedrsx
(Post 21088072)
as I read it, the only restriction on the secondary ecu is that it must not render the original OBD2 port inoperable, it may not utilize traction control, it must be in between the harness and the original ecu, and that it may not be spliced. it does not specify what or how it controls anything.
So you are free to add an AEM EMS, Haltech, Megasquirt, E-Manage, or whatever. |
Yup a haltech PS1000 piggy backed fits the bill! The only issue being the one current harness made on the market (awd) has issues according to Jeff Evans. He's still testing his kit and said in a PM the other day things should come together by next season hopefully.
The new pnp wouldn't be legal even though the two tuners do the same exact thing |
