Sway bar question
Old Nov 19, 2008 | 07:17 PM
D1sclaimer's Avatar
Default Sway bar question
Okay, I went along with everyones advice and got a front Whiteline sway bar. After I took it for a spin, I didn't really like the feel on turns, but Im sure I'll get used to it.
Now the question. When turning at speeds 35-45 miles per hour(not 90 degree turns) the rear end still is kicking out alittle. The thing thats concerning me is that I'll keep the steering wheel in the same spot and it'll kick, go back(to what it should be at), kick, go back, etc. Not a big kick either, but decently noticeable.
Im thinking I need to retighten the end links and thats my problem, but just thought I'd ask. I think its because I had the car jacked up when I tightened everything and when I lowered it down, it moved/loosened up? It is also a little chilly out which may cause it as well with grip. Or my alignment is out of whack.
Anything thoughts?
Old Nov 19, 2008 | 07:19 PM
D1sclaimer's Avatar
I was also wondering if I should have used the braces by the bushings from the stock sway bar? It didn't say to in the instructions.
Old Nov 20, 2008 | 03:24 PM
negcamber's Avatar
What tires are you running? Brand, model, sizes.
Old Nov 20, 2008 | 05:54 PM
D1sclaimer's Avatar
Stock size, Kuhmo Ecsta ASX on stock rims.
I didn't notice it as much today driving around.. I think its just the colder weather out(35-45degrees) and my alignment is messed up.
I went to a sub division(brand new and no houses yet) and opened it up alittle bit and it still did it, but not as bad tonight.
Chugs
Sep 12, 2011 08:58 AM
iLuveketchup
Jul 11, 2011 01:28 AM
Nickfromny
Mar 30, 2009 10:45 AM
Amer
Sep 6, 2006 09:35 AM
superjimbo
May 18, 2005 07:22 AM
