tie rod ends
Old Feb 17, 2011 | 11:41 AM
cracknut's Avatar
Default tie rod ends
On my racecar (track only), the boots are torn again on the tie rod ends. I believe the lowered front end is creasing the boot and causing it to eventually tear after ~600mi. Heat from brake rotors too?
I could replace with new boots for $20, new OEM rod ends for $70, or pillowball rod ends with no boots for $250.
Pillowballs worth it?
Old Feb 17, 2011 | 12:18 PM
speedengineer's Avatar
Don't know if pillowballs are worth it or not.
I too have oem tie rod ends on my (track only) S2000. I've only had it since last summer, but the boots last fine. I've done over 1000 track miles since I got it, and the previous owner a lot more. It is very low. However, since I do not run brake heat shields, I have added aluminum heat wrap around the tie rod and ball joint boots. Perhaps that is the problem.
Von_S2K
Sep 10, 2015 02:41 PM
#172CR
Dec 9, 2011 04:20 AM
patinum
Jul 19, 2011 09:56 AM
Greg W
Oct 23, 2010 03:06 AM
OldDogmeat
Sep 11, 2008 09:48 AM
