Tire pressures and alignment settings.....
Old Oct 14, 2006 | 10:02 PM
Ferrell's Avatar
Default Tire pressures and alignment settings.....
2001 S2000. The only suspension mods:
-Custom Roll Bar
-Buddy Club RS Dampers 10k/10k (approx 1.5in drop)
Tires:
-BF Goodrich G-Force T/A KD...... OEM Sizes.
I'll be getting an alignment this week....
Someone care to post what settings have proven to be most beneficial?
Thanks.
Old Oct 15, 2006 | 03:53 AM
RACER's Avatar
The more aggressive alignment you run, the more grip you will have, but at the expense of increased tire wear.
Try in between 30-32 cold psi front and rear to start. If the rear starts to rotate, drop a couple of psi in the rear.
Old Oct 15, 2006 | 04:42 AM
jlucas's Avatar
Is this pretty much a track only car?
If so, as much camber as you can get front and rear. Zero toe up front, rear toe in at the min of the Honda spec.
If not, I can't help.
Old Oct 15, 2006 | 08:34 AM
Ferrell's Avatar
If so, as much camber as you can get front and rear. Zero toe up front, rear to in at the min of the Honda spec.
Indeed it is....
Thanks.
Charper732
Feb 19, 2019 01:35 PM
RoninS2k
Nov 24, 2012 08:32 PM
ghostrider4evr
Mar 29, 2004 01:23 PM
TubeDriver
Jul 2, 2003 11:34 AM
laedwards
Jan 17, 2003 08:00 AM
