Tire Pressures for AutoX
Old Oct 13, 2003 | 06:09 PM
S2KBilly's Avatar
Member
Default Tire Pressures for AutoX
I am going to a AutoX this weekend. First time in a S2000 (2003) Stock Tire/wheels. Any suggestions on a close course tire pressure settings? The track will be set up for Porsche's.
Old Oct 13, 2003 | 06:16 PM
Ludedude's Avatar
Administrator
It really depends on track surface, temperature and weather. There's no out of the box solution that will work for every situation.
Old Oct 13, 2003 | 06:20 PM
payneinthe's Avatar
I use a pyrometer to figure out my baseline, then adjust from there. What I was ending up with on moderately grippy asphault was about 38 front, 37 rear (hot). Try starting there and adjust to suit. If you're understeering, try lowering pressure in the front. If oversteering, try lowering pressure in the rear.
I go as low as 33 hot, and don't seem to get any problems with the sidewalls rolling over.
Old Oct 14, 2003 | 07:37 AM
Gregg Lee's Avatar
38 front 34 rear (hot) was where I ended up on MY2000 for stock tire/wheeel. (And it still pushed on smooth corners, though you could get the rear around using trailing throttle oversteer) That was with more camber than stock, which is worth doing. Preferred settings for stock springs and stock or "normal" aftermarket shocks seem to be around -1.5 front, -2.5 rear.
You can might search for threads on camber, but they can be confusing since it will depend on other modifications. Lower, stiffer cars, or those with trick ax shocks to control roll may like a little less.
Gregg
[QUOTE]Originally posted by S2KBilly
Old Oct 14, 2003 | 09:10 AM
Surf2k's Avatar
35 front 36 rear on my02 w/ stock tires.
Old Oct 14, 2003 | 04:25 PM
S2KBilly's Avatar
Member
Thanks, I really appreciate the people on this forum. I will let you know more after Sunday.
ebchu
Jul 1, 2012 08:18 PM
xyster
Apr 21, 2008 06:31 AM
E-Z
May 1, 2007 12:51 PM
Driv300mph
Jul 17, 2004 07:27 PM
CFBH
Nov 28, 2001 12:03 PM
