Tire Trailer
Old May 24, 2005 | 06:11 PM
S2kSmiles's Avatar
Default Tire Trailer
I need to get a tire trailer for my S2000. Is it possible to configure it for 8 tires and a tool box and that can go long distances?
Thanks,
Kathy
Old May 24, 2005 | 08:03 PM
mikegarrison's Avatar
8 tires? Mounted? That's a lot of weight. Kind of pushing it, IMHO. Once you start talking more than a single set of wheels and a toolbox, it seems like you really ought to start thinking of a haul vehicle and car trailer.
Especially for long distances.
Old May 24, 2005 | 10:21 PM
S2kSmiles's Avatar
I don't have the space for a trailer or tow vehicle unfortunately.
Old May 25, 2005 | 02:40 AM
jguerdat's Avatar
8 wheels would need to take the place of the typical box on most of the small tire trailers. Maybe a small and/or thin one could work or put the tools in the car.
I haven't weighed a tire/wheel assembly for a while but 50 lbs. each would be a ballpark (more with certain wheels and tires, maybe somewhat less with others). That would give you 400 lbs. plus the weight of the trailer and any tools. Sounds chancy...
Old May 25, 2005 | 05:22 AM
Nickfromny's Avatar
NO. Tool box must go. Air tank can still ride on trailer tunge. Jack, Lug Wrench, Torque Wrench and all other tools should fit nicely in trunk. Line up tires either 4x4 or 8 in a row.
Old May 25, 2005 | 05:47 AM
Still seems like a lot of total vehicle weight, even if tools and such are in the trunk. Not that big of a deal for short distances, but more problematical for long distances.
Old May 25, 2005 | 07:31 AM
Elistan's Avatar
Regarding the weight:
- In steady-state driving on the highway, I don't see why there would be an issue. (As long as the weight is within the limits of the trailer's specs.)
- While speeding up and slowing down, however, more force will be required to accelerate the car/trailer at the same rate as before. (Unless you just really ease into it.) So you'd doubly want to make sure that your hitch is properly attached to the car.
- You shouldn't have any drivetrain issues - the car sees much greater forces during track/autox events, after all.
Regarding the logistics:
- I don't see how you could fit eight wheels/tires plus a toolbox on any of the trailers I've ever seen hooked up to a Miata or S2000. Tires on the trailer and tools in the trunk might work, though.
Old May 25, 2005 | 08:55 AM
Gregg Lee's Avatar
[QUOTE=S2kSmiles,May 24 2005, 09:11 PM]I need to get a tire trailer for my S2000.
Old May 25, 2005 | 09:32 AM
AquilaEagle's Avatar
Administrator
What hitch are you using on that Gregg?
Old May 25, 2005 | 10:10 AM
rlaifatt's Avatar
Looks like a Da'Lan like mine .
