Tire Trailer...
Old May 6, 2007 | 09:25 AM
gomarlins3's Avatar
Originally Posted by rlaifatt,May 6 2007, 08:08 AM
Do you feel that this design might not have enough tongue weight if your tool box is not carrying much? If you had to make one again, would you put the wheels in front and the tool box in the rear so that if your box is empty you can still tow the wheels? My Southsport has the wheels forward of the axel and the box rearward, and is very stable at high speeds irrespective of what's in the box. The wheels might also have better aerodynamics than the box in front.
Also, does the vertical mount of the spare cause clearance problems with speedbumps?
The tool box is heavier than the tires, trust me. When the trailer is loaded, I can move it around with two fingers. I would make it again the same way we did this time. It is also 40 inches wide and the gate into my backyard is 42 inches wide so i can put it behind my fence. Our CCR's will not allow a trailer to be stored infront of your house.
I have had the trailer up to 80 MPH and the trailer stayed right behind the car. The box barely sites higher than the trunk lid so I am not woried about the aerodynamics.
The car is FAR lower than the spare tire.
Old May 6, 2007 | 05:38 PM
cthree's Avatar
Administrator
Originally Posted by gomarlins3,May 6 2007, 01:25 PM
I have had the trailer up to 80 MPH...
Pussy
I've had my old HF trailer up over 100 and I followed behind davepk towing his at upwards of 130
Old May 6, 2007 | 05:59 PM
wing's Avatar
cthree, you don't still have the trailer or a hitch I presume?
I'll probably get the DaLan hitch but if anyone is selling...
Old May 6, 2007 | 06:02 PM
cthree's Avatar
Administrator
I have my hitch but not the trailer. Make me any offer and it's yours It's a dalan.
Old May 6, 2007 | 06:07 PM
wing's Avatar
Sweet! PM to you sir!
Old May 6, 2007 | 06:27 PM
gomarlins3's Avatar
I saw a Hammerly on sale on eBay yesterday.
Old May 6, 2007 | 06:54 PM
mikegarrison's Avatar
Actually, I put the box in front because I wanted to not limit the weight of my tool box to that of the wheels. If it were really necessary, it would be easy enough to carry some ballast. Toss a few cracked rotors in there and you are good to go.
But if I need to load the tool box a little on the heavy side, it would be harder to ballast the wheels.
Old May 7, 2007 | 10:51 AM
tinkfist's Avatar
People are bringing 200+ pounds of tools to the track? Are people saving their trunk space for dead bodies? I pack for a weekend like I'd be gone for a month and I fit everything inside the cabin and trunk with only 4 wheels on the trailer. I doubt if I will use my tool box on the trailer at all. The space has been nice for when I take the rain tires along as well.
Old May 7, 2007 | 10:54 AM
124Spider's Avatar
Extra rotors.
Air tank.
Assorted tools which I'd rather not have to take out of the trunk if I don't actually need them.
I put the "containerized" things in the trunk, like the impact wrench. Sometimes I put the jack in the trunk; sometimes in the tool box.
I've never had a problem filling up both trunk and tool box.
Old May 7, 2007 | 11:16 AM
Conedodger's Avatar
I experimented with the balance of my HF trailer and found it was best with the tires up front. I carry a small cooler on the tongue, the spare is mounted under the front of the trailer. The tool box holds a HF aluminum jack, small air tank, and a rubber maid tote with the impact wrench, torque wrench, pyrometer, magnetics, gloves etc. I don't carry tools, cause it's a Honda! (There are enough friends around that bumming tools is never an issue.)
With the above setup, the trailer weighed in at just over 500 lbs. I've got about 52 lbs. of tongue weight.
I like to keep the trailer self contained. When I get home from a local event, I wheel the trailer into the garage and I'm done, no unpacking. This way the trunk is free for packing for the out of town National Tours and such.
