tire trailer wiring guide?
It's been a long time since I installed my module but I just used the wiring diagrams for color codes. Looking at the PDF version of the 2000-2003 manual, brakes are on page 22-64 (white/black), turn signals on page 22-77 (green/yellow), tail lights on page 22-63 (red/black).
I think the module is near the left taillight assembly...
You need a 5 wire to 4 wire converter. If you have LED tails, you may want to use the isolating harness with external power otherwise your trailer turn signal might cancel cruise control
I just used my volt-ohm meter to pick the wires. It took me about 3 hours to tear apart the trunk, locate the wires, tap into them, tear apart the interior, run the external power, reassemble everything, then verify.
get a 4 wire converter from UHaul with it's own power source, i think it was $45. if you get one that use power from the signal wires, the lights on the trailer will be very dim and you might blow fuse. i keep blowing fuse, so bought a converter with it's own power source.
The harness is part of the module and comes with taps so you don't need to cut/splice wires. Mine doesn't have a power lead yet has run both a kayak and tire trailer with no problem. Obviously, it depends on the exact lighting setup.
Also, I wouldn't run the trailer plug through the vent under the bumper unless you never drive in wet weather. I had to redo the vent on mine even though it had never been touched due to water in the trunk (from multiple places).
