Track event approaching - recommendations
Old Jun 16, 2006 | 10:54 AM
Intense's Avatar
Default Track event approaching - recommendations
First, I know every has an opinion on they're favorite pad. So, I'll just list my requirements and you guys feel free to try to sway me in whatever direction.
I'll be in CMP (Carolina Motorsports Park) next weekend for both days. I've been cleared to run in the solo group, having about 12 track days under my belt. Although, I've only been on CMP once previously. This track is notoriously hard on brakes.
My plan is to swap to the 'track' pads next Friday and running them through the weekend and going back to OEM pads afterwards. BTW, I'll be running R-compounds. Right now, I'm thinking the Carbotech XP-8/9s
The hard part will be getting the pads before next weekend.
Second, looking at my current alignment (stock). The car would benefit from more negative camber. I've never done any indepth research, but is there anyone that makes camber bolts for these cars?
thanks for your time
mike
Old Jun 16, 2006 | 11:02 AM
Iceman1's Avatar
mike
how much camber are you looking for?
Old Jun 16, 2006 | 11:10 AM
Intense's Avatar
I'm thinking -1.5
Old Jun 16, 2006 | 11:11 AM
mikegarrison's Avatar
XP8s should be fine. That's what I'm using these days. But of course it depends on too many variables to be sure.
Old Jun 16, 2006 | 11:18 AM
Iceman1's Avatar
[QUOTE=Intense,Jun 16 2006, 02:10 PM] I'm thinking -1.5
Old Jun 16, 2006 | 11:20 AM
Stratocaster's Avatar
Yes, that is within the OEM spec. I think -2 is part of the UK spec.. But if you are lowered, forget it.
Old Jun 16, 2006 | 11:24 AM
Intense's Avatar
Originally Posted by Iceman1,Jun 16 2006, 11:18 AM
you should be able to get that with the stock suspension.
oh..ok, I guess I should know that...my bad.
To go further, is there any camber bolts to dial in more neg camber?
Old Jun 16, 2006 | 07:21 PM
robinson's Avatar
AFAIK there are only 2 items you can purchase to get more camber. The SPC replacement upper ball joint that is adjustable, and the adjustable upper A-arm from GFL.
I have the SPC, and on stock springs and shocks I maxed the camber up front at -3.1 degrees.
KevinATL
May 20, 2016 12:24 PM
JSenek
Apr 9, 2015 01:00 PM
s9000
Nov 5, 2002 04:24 PM
ScienceofSpeed
Sep 26, 2002 03:27 PM
y2ks2k
Aug 18, 2001 07:17 PM
