track time!
Old Jul 30, 2010 | 01:06 PM
hypforlife32's Avatar
Default track time!
hey guys im going to the cecil county dragway tonight, mods are aem v2 intake-greddy tic single-70mm invidia test pipe, giles tune, 1 step colder plugs, aem uego wideband. ill post up times later on. im hoping for a 13.6 again at 104
Old Jul 30, 2010 | 01:51 PM
common reactor's Avatar
Good luck
Old Jul 30, 2010 | 04:39 PM
siik_ap2's Avatar
should be doable...mph is a bit high....prob be closer to 101-102...
Old Jul 30, 2010 | 09:18 PM
yeah, all of my decent passes i missed 2nd. i was furious. had 3, 2.1 60fts all 14.3 passes at 102mph with missing 2nd gear. then on the runs i didnt miss 2nd i get 2.3 60 fts and trap 100mph and run 14.0. i was so agravated i just gave up after 5 runs. it was erratating. after the first two runs i tried consatrating more on my 60 ft and wasnt paying much attention to my shifting. it was all over the place. bad bad night for me.
Old Jul 30, 2010 | 10:12 PM
spike109u's Avatar
That doesn't sound so bad. Your trap is where it's supposed to be, and a flat 14 is certainly not a bad time.
Old Jul 30, 2010 | 10:22 PM
OneSilverS2k's Avatar
Your running a 13.6 with that stuff?
I have a stock S2K< I brought to the track and did fine, but my best was a 14.9? @ like 96 the hell am I doing wrong!
Old Jul 30, 2010 | 10:51 PM
spike109u's Avatar
What's your 60' time? You should be trapping a little higher than that. What RPM are you launching at? Keep in mind 13.6 is a really really good time for those mods though.
Old Jul 31, 2010 | 07:49 AM
yeah, the best time i ever had was a 13.6 at 103.79 mph. then i had a couple 13.8s that night as well, granted it was 30 degrees colder.
spike, your elevation could also be killing you. depends where your track is located as well.
Old Jul 31, 2010 | 11:17 AM
I will have do just do a compression check, I shift at about 8900 RPMS each gear, and I do it quite fast.. ill go get some of my time slips I really want to run better times !
Old Jul 31, 2010 | 12:53 PM
siik_ap2's Avatar
im not sure if the one step colder plugs are helping you..
edit:
did you happen to weigh your car???
