transponder location
Old Dec 27, 2012 | 05:33 PM
hondalovr13's Avatar
Default transponder location
so i just got a transponder and i am curious as to where a good spot to put is. i know the front bumper is the most common spot, but i got the wired one instead of the battery one. so i wanted somewhere where i can wire it easily and not worry about it. also what circuit is the best to wire it into or how is yours wired. any help is appreciated.
Old Dec 27, 2012 | 05:48 PM
CKit's Avatar
You can do wired with quick release connects.
Old Dec 27, 2012 | 06:37 PM
robrob's Avatar
I permanently wired mine on the bottom of the center radiator support (in front of radiator) using 4 zip-ties. You should be able to reach through the nose hole to mount it. I ran the wire up to the fuse box on the passenger side near the front shock tower. Make sure you get a switched hot so you don't drain the battery.
Old Dec 27, 2012 | 07:03 PM
did you go right to the fuse or did you splice the wire?
Old Dec 28, 2012 | 06:55 AM
Liquidsation's Avatar
here is example and not sure which fuse location that is but it is switched hot. I had a friend help....do it for me:
[attachment=32079:100_0956.JPG]
[attachment=32080:100_0953.JPG]
Attached Thumbnails transponder location-100_0956.jpg   transponder location-100_0953.jpg
Old Dec 28, 2012 | 07:08 AM
robrob's Avatar
I wired mine exactly like liquidstation's photo.
Old Dec 28, 2012 | 03:20 PM
it looks like that's just an inline fuse from a subwoofer hook up. thanks for the info I will be putting it in this weekend.
Old Dec 28, 2012 | 08:29 PM
Yup, basic inline fuse for piece of mind.
Old Dec 29, 2012 | 11:45 AM
so did you just take out the relay there. mine is in place and it says its the clutch relay. is it not needed or does the relay still fit in with it?
Old Dec 29, 2012 | 01:42 PM
My replay is removed. I think it is the A/C clutch relay so not needed on race car. Better check the shop manual first to make sure.
