Video of Paddle Shifted S2000
I thought this was interesting:
These two articles explain some of the complexities. They assume a dog-gear, sequential transmission in contrast with the dual-clutch synchronized or planetary-gear transmissions used in current production car paddle shift systems. Exploding the myths about shift times: http://www.geartronics.co.uk/shift_times.htm The reality of clutchless auto-blip downshifts: http://www.geartronics.co.uk/blippers.htm |
Originally Posted by DavidNJ
(Post 24415976)
https://www.youtube.com/watch?v=EojOhUg5UJg These two articles explain some of the complexities. They assume a dog-gear, sequential transmission in contrast with the dual-clutch synchronized or planetary-gear transmissions used in current production car paddle shift systems. Exploding the myths about shift times: http://www.geartronics.co.uk/shift_times.htm The reality of clutchless auto-blip downshifts: Geartronics - Exploding the myths regarding shift times! |
Originally Posted by Mrsideways
(Post 24416369)
I'm going to assume this is on the quaife seqential
Geartronics stuff doesn't work on H-pattern shifters. |
There are quite a few sequentials that use the Geartronics: Sadev, Samsonas, Albins, Hewland, etc. in addition to Quaife. Quaife does sell a ready to go set up for the S2000 including input shaft and bellhousing. Hewland sells their own paddle shift control, Motec has version of their ECU that support paddles, but the paddles, air pump, air tank, and actuator are separate. Geartronics also has a version for rally cars that mounts on the side of the steering column and shifts with either forward or back pushes.
Originally Posted by Driven
(Post 24416397)
It is.
(Post 24416462)
oooff $11,000 for the trans.
https://cimg1.ibsrv.net/gimg/www.s2k...2c05cbcb2a.jpg |
(Post 24416487)
I think it is a bit over $14k for the transmission, plus $4k for the Geartronic paddle shifters. The Motec GPRP firmware and the paddle shifter kit would be closer to $5k, in addition to the M130 ECU itself. Add the time to wire and plumb the setup including fabricating brackets. When the dust settles, a paddle shifted, sequential, dog gear, straight cut transmission is probably $20k. Someone did sell a complete used one for £7000, about $10k...undoubtedly plus shipping.
(Post 24416710)
Or sell the car, buy a used Cayman with a PDK for the same amount of money. 7950 converted to USD was about $11k. Need the British pound to drop a bit more.... like half, before I'd consider.
For street use, the Porsche would be better for a lot of reasons. As a dedicated race car, it's probably less expensive to run an S2000...just the F-series/K-series motor costs vs. a Porsche-anything would be a huge difference. |
(Post 24416714)
PDK is a dual-clutch manual...a different type of transmission. This is a dog gear transmission with straight cut gears; the DCT is a synchro transmission with helical gears. For example, the AMG GT/S/C/R models in all the road tests have a DCT transmission. No one would use straight cut gears and few would use dog gears (there is only one Fiat not available in the US) for a production street vehicle. However, the AMG GT GT3/GT4 models, sold as complete racing cars, have a sequential, spur gear, dog gear engagement transmission with paddle shifters. Ditto the Porsche track GT3R, etc.
(Post 24416710)
at $20+k, sell the car, buy a used Cayman with a PDK for the same amount of money. 7950 converted to USD was about $11k.
