Weight reduction: What are the best mods?
Hey guys,
I have been tracking my 2005 and generally have been very pleased. The only mod I have done so far is a set of Tein coilovers. I want to reduce the weight of the car by a couple of hundred pounds. What do I need to do to make this feasible? Where can I save the most weight? Thanks in advance Tony |
pull out your interior. I did mine tonight, and must have taken 200lbs out of the car:
http://tastybeef.com/s2k/s2k-interior2.jpg It looks prettier in my spare bedroom: http://tastybeef.com/s2k/s2k-interior.jpg -- Brian |
what about convertible roof system.. airco..
Get lighter wheels for starters. It's unsprung and will give you the best bang for $ weight wise. 17" Volk CE28N
-3 Mats/Visors
-30 (5 Gal Gas) -12 Optima PC600 Battery -15 Recaro SPG -32 Remove passenger seat -18 Tein RAs -5 Center Console -10 Stock Rollhoops/Plastic -2 Washer Fluid -3 Cruise control unit -30 Wilwood Dynalite Brakes/Rotors -1 Hood insulator -5 Flywheel -10 T1R test pipe (no cat) -20 AC Compressor + lines + Radiator + Fluid -5 AC Evap Core + rubber hose -20 Stripped Hard top -8 Rear sway bar -15 Volk CE28s -15 Header -15 Dash -15 Airbags -6 Wipers/motors -30 Gutted doors |
Sorry, I had to. :rolleyes: |
Originally Posted by Nobody,May 29 2006, 08:16 AM
-30 (5 Gal Gas)
The first things I would do, would be... remove spare, tools, get lighter rims and exhaust |
I have single exhaust with test pipe -60lbs
gutted trunk -42 lbs J's header -13 lbs emptied windshield washer reservoir -8 lbs cold air intake -3 lbs coilovers -12 lbs SSR Comps -16lbs drycell battery -15lbs (I'm locating mine in rear to help with weight ratio - most is removed from rear so rear end can get trigger happy sometimes too often) I will also be removing my front bumper support, which is supposedly another 12-15 lbs. I will leave in the rear because I do not want to take out any more weight out of the rear. I just need to figure out another 15-20 pounds and I'll reach my goal of -200 pounds before gasoline. Maybe CF mirrors? How much do stock mirrors weight? I only fill up with 10 dollars worth of gas at a time, which is usually only 3 gallons so I'm saving another 60-70 pounds there. Good luck with your weight savings. |
