Weird rear end feel help please
Under heavy braking the rear end feels like it sways left and right like its loose
Unde accel it pulls left and decel pulls right
I've read a lot about the tire pressure problem but its even. I've tried 2 different rear rims and the same effect
I am about to check subframe bolts.
Any other suggestions?
I've done both rear wheel bearings and check all suspension bolts
Alignment has been done twice by a reputable shop and suspension is near new eibach r2
Tires are hankook rs3. Rear toe arms are Megan
Could be a combo of worn out dampers and crumby soft side walled tires. Too much suspension moment in braking/dive will cause the rear to unload and toe out, accelerating does the opposite, throw some crumby tires on there and it could be the icing on the cake. Whats your alignment spec? Maybe thats f@#ked up.
A friend had an interesting issue where the welds that held the offsetting plate for the front inner lower control arm bolt broke free allowing the bolt to squirm. Before he repaired it he told me about how unpredictable and loose the car felt and then after what a relief it was. Maybe it's worth a look?
MIne did this when I had RC5+ front and back so the bias was messed up. heavy braking would cause the back to shimmy. Guessing it was the bias, but now with XP 10 F and XP 8 R problem solved.
When you tried different rims, was that with different tires as well?
Any time you get weird left/right pulling symptoms like this and pressures are equal, swap the tires left/right and see if the problem changes direction. Could have a bad one...
