What is corner balancing??????
Old Oct 26, 2003 | 07:40 PM
Kekoa's Avatar
Default What is corner balancing??????
I just joined the Buddy Club today and was wondering if its worth getting my car corner balanced when I go in for the allignment. Is corner balancing recommended with race spec dampeners?? How will it help??
Old Oct 27, 2003 | 03:32 PM
minboost's Avatar
corner balancing is when you balance the weight distribution over each wheel so that the sum of the front left+rear right = front right+rear left corners. This will also give you the total vehicle curb weight and help determine front/rear weight distribution.
One of the main reasons for getting a coilover system is to be able to corner balance the car.
Old Oct 27, 2003 | 03:57 PM
Kekoa's Avatar
TKs mIn. Imma give it a try.
Old Oct 27, 2003 | 07:12 PM
pfb's Avatar
pfb
Of more importance than corner balancing is just determining the optimum ride height, spring rates, and damper settings for your car and the kind of driving you will be doing.
Corner balancing is going to be very damn close if you use identical "turns" left to right and aren't far off front to rear. The S2000 is extremely well corner balanced from the factory.
Old Oct 27, 2003 | 08:05 PM
Kekoa's Avatar
These freakin buddy clubs have so many settings that I don't know where to start as far as optimum ride height, spring rate, etc. All I know is that I don't rub right now and all sides are equal heights. I have fronts set a 11 out of 15 and rear at 9. I'll try this out and see how it handles. I desperately need the allignment tho.
Robertttstyle
Mar 24, 2014 10:59 AM
Wombo
Feb 21, 2009 04:48 PM
dms2k
May 7, 2004 01:09 PM
The Reverend
Apr 14, 2003 10:39 AM
