wheel set up?
i have a 05 s2k i just bought some rpf1 wheels 9in all the way around. ive heard people saying a non staggerd wheel set up will affect the handling in a bad way? is this true? i road race my car once a month its a stock powered car with tanabe sways and gf210 springs the car has been lighten also. and will i need a gt wing for running this kind of set up? any help will be appreciated.
you will probly experience some oversteer with the wider tires , what tires you running ? I would do Alignment also shoot for -2camber front max caster 0 toe , -3 camber rear 1/4 + total toe rear maybe a little more to tame down some oversteer you might have . Hold off on wing , you might find out there is still to much oversteer . report back after track day . good luck
i say just drive it like that at the event and see how u like it/not like it and just go from there...
everyone's driving style is different. obviously, it will have more oversteer, but your skill level/driving style may or may not be able to compensate for it. hope that helps.
Originally Posted by robinson,Jul 8 2009, 06:13 PM
What are your spring rates? If they are not stiff enough, you may need a larger front bar and/or the rear wing to keep the rear in check.
G.E
Apr 25, 2012 03:27 AM
TwisS2000
Apr 18, 2012 04:52 PM
