Where to place Accusump
So heres the deal. I am SOS supercharged and aftercooled, so I cannot place my new Accusump on the crossmember in front of the engine. I also am using a larger radiator with SPAL fans, so it will not fit on the front of the crossmember either. It is a little too big to fit where stock battery and fuse box go, so I was thinking I could put it in trunk/ spare tire area. I run a lot of HPDE, so still need a passenger seat, so that area is out. My question is, if I put it in the spare tire area, is the oil line back to the motor too long to be of any benefit? Even with a -10 line from Accusump to the sandwich plate adapter, would I see decreased pressure to the point where I lose the benefit of the Accusump. I am running an oil cooler and I will be using the manual shut off valve. Opinions are needed and appreciated.
Thanks
Brandon
Thanks
Brandon
for_my_s2k
Aug 11, 2012 12:27 AM
Fast Jack
Jan 5, 2009 01:16 AM
stryder9
May 19, 2002 08:19 PM
