Wink mirror & no side views?
Old Oct 30, 2013 | 07:51 AM
s2kreeper's Avatar
Default Wink mirror & no side views?
Anyone know of any regulations for side view mirrors? I googled, targeting nasa and scca (prepared class) and nothing came up other than people saying they use aftermarket.
I'm looking to drop them all together and just use a big 5 panel rear view. Do they provide a wide enough view angle? I still DD my car and my local law says only have to have a mirror allowing rearward view of at least 200 ft. I also ___ALWAYS___ turn head when merging/switching lanes.
I figure it's decent way to decrease drag as well as maybe save 2-4 lbs.
Old Oct 30, 2013 | 07:57 AM
iamxpl's Avatar
not to rain on your parade, but 2-4 lbs is not worth saving especially if you still drive your car daily. god forbid you have to parallel park. and not to mention safety. i mean if your local law allows you to remove the side mirrors go ahead and do so if you wish. i think the wink mirror would be beneficial if you had a halo type seat since it obstructs your side view. i cant comment how much or how effective wink mirrors are since i have yet to see anyone here with them. and personally i think the car would look weird without the side views.
Old Oct 30, 2013 | 08:08 AM
s2kreeper's Avatar
I can't help but feel I'm going to end up with a hard top version of this eventually
Old Oct 30, 2013 | 08:13 AM
dan_uk's Avatar
you'd have to try it I drive a chumpcar with that setup and it sucks not having any side mirrors for me
Just from looking at the car I think the mirrors push the air out round the back of the car and onto the wing
Old Oct 30, 2013 | 08:57 AM
Mahjik's Avatar
It depends on the competition type and class. For instance, you can remove mirrors in NASA for TT and some race classes. However, classes like Honda Challenge require some type of mirrors so you cannot remove them completely (only replace).
Personally, I don't think you'll gain anything by it unless it's a pure autocross vehicle like the one you posted. Most racing/track folk want increased visibility as once you strap on a HANS (or other H&N restraint system), your visibility is limited by mobility. A lot of drivers even add small spotter mirrors in addition to the larger rear view mirrors and their side mirrors.
Old Oct 30, 2013 | 10:28 AM
BlueBarchetta's Avatar
I use a Hans, recaro pro racer "halo" type seat, side view mirrors and Wink rear view mirror.
The wink mirror gives you a very wide view, however, the farther to the sides the more the view is not linear.
Therefore I'd recommend you keep the side views, as I always use them to check clearance when passing. Much more realistic. I do however highly recommend the wink mirror. It greatly increases situational awareness at a quick glance
Old Oct 30, 2013 | 10:54 AM
blueosprey90's Avatar
Although I don't use one on the S2000, I do have a Wink Mirror on my MGA. I've cut it down to three panels.
Although it's really cheap, I'm not sure the Wink Mirror is the best option. You will likely get a great view of the roll bar, hardtop and wing. But whether you will actually see any cars behind you is open to question, especially with all the business as shown in post #3.
On my set up, I have to look pretty far behind to ID the cars coming up. Then once I have an idea what's coming, I can more or less anticipate their presence and location when they get close. But on first glance, all I really see is my roll bar.
Moreover, I still have a blind spot on each side of the car with the Wink. All of the Wink mirrors are flat.
I would love to get three of these for the MGA, one for the center rear view and one for each wing:
https://www.pegasusautoracing.com/bi...sp?RecID=10145
Although I can't speak for SCCA or NASA racing, in vintage, most organizations require at least two mirrors. The problem in my experience, is that two mirrors aren't enough. I would go only with convex.
Also, just as an aside, when you are holding on for dear life in a corner with a car on your rear quarter, you can't be turning your head and looking around to see if it is safe to dive in for the apex.
Old Oct 30, 2013 | 04:14 PM
Cooper4x's Avatar
I had a 5 panel wink mirror installed for a while. there was zero benefit with a hardtop installed. In fact, it was worse because it rattled and vibrated making it hard to visualize clearly and fast. I went back to stock very quickly because of that. Tried it on track and street
Old Oct 30, 2013 | 04:49 PM
Langelo DeMysterioso's Avatar
I used to have a wink mirror back in the day. Vibration was definitely an issue.
Old Oct 30, 2013 | 07:51 PM
davidc1's Avatar
I would absolutely not recommend this. I'm doing it now in my DD and it's absolutely dangerous on the street. I'm driving this 93 Civic DX in which the right side mirror was optional, and the original purchaser decided against it. In addition, my drivers side mirror just broke.
Even with turing my head around with every lane change I've come close to hitting cars multiple times. You absolutely need to keep your side mirrors. I had no idea how much of an extra view they give you over the rear view and even turning your head.
