S2000 Street Encounters Stories of on-the-road exploits and encounters.
grudge match this weekend
Old Dec 11, 2012 | 02:23 PM
wrecked's Avatar
Default grudge match this weekend
I'm about to get into a little grudge match for some money (100-200 dollars..) we will be running in low to mid 40s weather condition so I know I wont have that much grip. I'm running 265 star specs.. pretty worn. IDK if i will be able to get some heat in the tires by doing a burnout or not.. But I would just like some advice on tire pressures, technique and suspension settings. I'm running KW V3 coils btw currently on the stiffer end of both rebound/compression settings.. So here is what I am planning on doing and would like some feedback.
1. lower rear pressure to 26 psi
2. raise front pressure to 40 psi
3. soften up rear compression settings 7-8 clicks
4. bring rpm to 5k and release clutch quickly.
should this give me a bit of an edge? What else can i do? My titanium exhaust broke so I'm stuck driving around with this heavy ass stock exhaust for now.. I was thinking about removing it and running open header for the run.. (i have a TP)
getting pretty stoked and its worth changing some things on the car since some money is at stake. hahaha lmk what you guys think
Old Dec 11, 2012 | 05:35 PM
Moddiction's Avatar
Former Sponsor
What car are you racing?
Old Dec 12, 2012 | 01:55 AM
wrecked's Avatar
A pos old neon 5 Spd with a 50-75 shot of nitrous, sticky tires, header, and tune probly. The point is he wants to try and embarrass me by beating me in a shitty old car then tell the world about it
Old Dec 12, 2012 | 01:49 PM
KaNgArOo's Avatar
He might beat you. If your car is stock powerwise.
Old Dec 12, 2012 | 09:20 PM
s2000maniac's Avatar
So who won?
Old Dec 13, 2012 | 04:26 PM
wrecked's Avatar
The race is supposed to go down this Saturday at 5. If it does happen, I will be sure to get video and post it here
Old Dec 13, 2012 | 04:28 PM
wrecked's Avatar
On a side note, I practiced my launch today with the e brake for preloading and it came off the line pretty good.
Old Dec 14, 2012 | 08:21 AM
Boost76's Avatar
I've seen NA neons run 14s at the track. hahaha unsure what was done to them. This was before the SRT4 edition. If its a POS like you said then he would still lose. I had a buddy with 50 shot wet with a 95 civic EX run 15et. in the 1/4 mile. Unless you got a lemon for an s2000 you should at least be able to do 14s without any effort.
Old Dec 14, 2012 | 08:17 PM
r34dy2fly's Avatar
"Sticky tires" don't exist in this temperature range unless you run a few laps on the track or heat treat them before hand. I'm on Pilot Sport Cups and nothing in this temperature heats them up long enough to gain traction. I suppose use it to your advantage.
Old Dec 16, 2012 | 05:58 AM
wrecked's Avatar
welp, he was BSing the whole effin time
