S2000 Street Encounters Stories of on-the-road exploits and encounters.
hit 269 kph yesterday....
Old Feb 19, 2002 | 05:53 AM
PLYRS 3's Avatar
Default hit 269 kph yesterday....
was booting along on the 407 (VERY expensive toll highway in toronto, canada) yesterday...
speedo hit 269 before i shut it down.
269 kph equates to 165.5 mph - that's 10 (if 155) or 15 (if 150) mph more than the car is ELECTRONICALLY limited to.
so here's the question------> can the speedo be off by THAT much? or does the car really keep pulling until it can no longer do so mechanically (not electronically)?
i'm quite curious....
(btw, i had the hardtop on)
regards.
Old Feb 19, 2002 | 06:27 AM
suvh8r's Avatar
Old Feb 19, 2002 | 06:39 AM
PLYRS 3's Avatar
yes, i agree
it won't happen again, officer.
Old Feb 19, 2002 | 06:54 AM
espentan's Avatar
I didn't think the S2000 had a top-speed limiter?
I don't know how accurate the speedos are in this car, but if you got a 269 reading you were probably doing a solid 250 km/h. Not bad for a little 2 liter
Old Feb 19, 2002 | 07:00 AM
espentan's Avatar
I never get tired of watching this
http://www.tandberg.org/temp/s2k_167mph.wmv
Old Feb 19, 2002 | 06:43 PM
DavidM's Avatar
S2000 does not have any 'electronic speed limiter'. It's top speed is limited simply by the power and aerodynamics. What that means is that if you find a long enough downhill strech and you run the 6th gear all the way to redline then you'll be actually doing 269kph (275kph if you're bouncing of the rev limiter - that is if the rev-limiter is at 9,200rpm).
S2000 cannot reach any higher speed than that because the gearing does not allow it to ... though there's no actual 'limiter'.
What revs were showing on your tacho when your speedo was showing 269kph? If you know, you can work out how much speedo error you have but 15kph at those speeds is not unheard of.
Old Feb 19, 2002 | 09:05 PM
dhess's Avatar
Thats insane.
My best effort was 258kph with the roof down. Talk about wind rush!
Old Feb 21, 2002 | 07:01 PM
xtc@9k's Avatar
I'm still looking for that hill, the best i've done is 254kph.
Old Feb 22, 2002 | 04:56 AM
PLYRS 3's Avatar
hi all,
yes, it was a little downhill as i hit that speed - i had it floored going UP a slight incline and carried a lot of momentum as the grade became downhill.
it was a rush that's for sure.
question: is the car more aerodynamic with the hardtop on? i would assume so, but i don't know.....
regards.
Old Feb 22, 2002 | 12:13 PM
airsport's Avatar
[QUOTE]Originally posted by TKG 26
[B]hi all,
