S2000 Street Encounters Stories of on-the-road exploits and encounters.
How do you "properly" drop the clutch
Old Oct 3, 2006 | 04:15 PM
dmw16's Avatar
Default How do you "properly" drop the clutch
Inspired by another thread on here...
someone said there is a right and wrong way to dump/drop the clutch. Could someone explain how to do it properly?
Old Oct 3, 2006 | 04:34 PM
Currahee474's Avatar
its split with many people between dropping it or feathering it out.
i personally drop and i have never had any problems with the diff.
Old Oct 3, 2006 | 05:03 PM
KnowledgeIsPower's Avatar
many people say sidestep the clutch, but personally i dont understand how they can with the pedals so close and the footrest an inch away from the clutch?
is there a differance between ap1 and ap2 setup?
i just "drop it" by lifting my foot as fast as possible but some people say that will still cause some slipping?
Old Oct 3, 2006 | 08:36 PM
GRUNTS2K's Avatar
yeah there isnt much room down there.....
Old Oct 3, 2006 | 09:16 PM
EK9MAX's Avatar
yea i tried to sidestep toda.y footrest got in the way....
Old Oct 3, 2006 | 09:41 PM
diabolus2k's Avatar
I have the same problem too, and my size 12 feet don't help either. It's tough for me to launch properly by "sidestepping," so I just don't launch my car at all anymore...
Old Oct 3, 2006 | 09:43 PM
Spec_Ops2087's Avatar
I can't side step eithor and I have pretty narrow feet. I just rev her to about 6kish, pull my left foot up as quick as possible, floor it, and the car will go straight to redline but will drop down and catch traction at like 8kish rpms. The perfect launch
Old Oct 3, 2006 | 09:55 PM
REVZ TO9's Avatar
Banned
yup, I agree!! Also, the more the bogging, the more likely you can damage your diff if you dont launch high enough in RPM range
Old Oct 3, 2006 | 10:35 PM
donger274's Avatar
what is sidestepping? never heard of this method before. why and how does it help?
Old Oct 4, 2006 | 07:24 AM
Penforhire's Avatar
The S2000 clutch is very hard to lift your foot off fast enough to do a proper launch. It is much more consistent in grabbing for a high-RPM launch if you "dump" the clutch. If your foot is too big then move it over as far as you can and roll your ankle until the pedal slips out from under it.
Otherwise the risk of slipping is too high. Do it once (spin in place and stink) and you'll glaze the clutch. Performance will eventually return. Do it too often and your clutch is toast ($$$).
