S2000 Street Encounters Stories of on-the-road exploits and encounters.
Raced an 05 s2k with my 08 s2k Cr
Old May 8, 2009 | 11:34 AM
s2k 4u 2nv's Avatar
Smile Raced an 05 s2k with my 08 s2k Cr
Ok so Is this normal. I race my buddys stock 05 red s2000 with by 08 black s2000 cr and lost pretty badly both of a digg and a roll. anyone got ideas on the outcome.
Old May 8, 2009 | 11:45 AM
tof's Avatar
tof
I wonder what might be under your buddy's "stock 05" hood and/or what he might have inside the rear dif housing.
You might also try swapping cars and see if the results change.
Old May 8, 2009 | 11:50 AM
NoRawkus305's Avatar
There shouldn't be much difference truthfully from an 05 and 08. It should've been practically even if both were stock. You might want to check your buddy's if he is really stock. The other possibility is driver skills. As another mentioned, switch cars and see if the results are the same.
Old May 8, 2009 | 12:06 PM
#172CR's Avatar
turn ur VSA off
Old May 8, 2009 | 12:12 PM
Saki GT's Avatar
What qualifies as "pretty badly"?
GPWonTan's Avatar
driver skill plays a huge part in any race. although it should be less so if from a roll...
Old May 8, 2009 | 12:44 PM
s2k 4u 2nv's Avatar
Roll like 3 cars and digg like 2 VSA was off lol
Old May 8, 2009 | 12:55 PM
xeuxx's Avatar
Switch cars...
Sounds like driver Errrorrrr
Old May 8, 2009 | 12:56 PM
ace123's Avatar
You are only 50-100 lbs lighter, and you have the same or practically the same power. keep in mind, if he removes his spare, that small weight advantage could be zero. it's worse yet if he's thin and you're not. roughly, you have as much as a (100lbs/2850lbs) = 3.5% advantage in power-to-weight ratio (in theory). the square root of that is your acceleration difference: up to +1.7%.
a car that is 1.7% faster could be soundly beaten by the 'slower' car using better shifting and a better launch. your buddy probably beat you because he's had his car longer and knows how to drive it.
Old May 8, 2009 | 01:19 PM
s2k dre's Avatar
How many miles on the 08? My car didnt trap 101mph in the 1/4 mile till it had 35k on the motor. These cars get noticable faster when broken in.
