S2000 Street Encounters Stories of on-the-road exploits and encounters.
What do you launch at?
Old Apr 24, 2005 | 09:36 PM
User 32625's Avatar
Default What do you launch at?
So I ran against my friends 96 cx hatch with a b18 tonight and beat him by a car lenth the others said.....his motots built and all this...thing is he spun the tires all through first so Im wondering if when i run next week if ill get a kill on him.....also when I launched it seemed to bog down...
what do yall launch at????
i figured all motor i should go around 3/4 somewhere in there but whats yall opinions and what do yall do???
any info would be greatly apreciated seeing as ill be running him again next week and i dont wanna lose and get that 'oh last week you were lucky' ordeal lol
thanks, mark
Old Apr 24, 2005 | 09:50 PM
YellowS2kPwr's Avatar
7,000. Drop it like it's hot
Old Apr 24, 2005 | 10:14 PM
vAnt's Avatar
3k/4k=bog everytime...
I think you need to be closer to VTEC to not bog.
I'm too scared to launch at VTEC though ;x
Old Apr 24, 2005 | 10:18 PM
S2oooNvegas's Avatar
2 things, what year is your car? and what clutch do you have?
you have to decide where to launch by the surface. if its smooth, leave a tad lower, if its way rough, leave high. either way, the goal with a small motor car such as this, is to leave and have the wheels spinnin, yet grabbing as they go, so not too much wheelspin. its a technique called clutching, no it has nothing to do with your clutch, thats the name for the tactic to having the tires hook every other or every third rotation. the car will set (rear end drops) and yet the tires will spin, keeping the rear end planted yet your going forward fast as hell. this is the ideal launch. bogging is no good, and having to backpedal is no good. so, just practice, if you have an ap2, youll be alot better off, if its ap1, its much harder to launch, as the gears are too high. anyways. PM if you have any questions.
Old Apr 24, 2005 | 10:28 PM
Hamiy's Avatar
How much can the AP1 clutch handle?
I have been launching at 3k/4k and yes, always bogging down. It's no fun.
Old Apr 24, 2005 | 11:23 PM
SOHCmyDOHC's Avatar
I left at 6k (At VTEC basically) and no bogs... Scary though..
Old Apr 25, 2005 | 12:15 AM
9kFever's Avatar
ap1 here and launch in the 7's....no bog....
Old Apr 25, 2005 | 04:14 AM
Reds2kracer's Avatar
I launch my Ap1 at 5500rpm, not right on vtec but right there after it takes off. 3k-4k launch are way too low and you'll get raped, you can try launching at 5500rpm and not stomp all the way down 'til it starts to grab then floor it to avoid too much wheel spin. I did that when my tires were shitty, no tractions and it just burns when I floor it after launching so this techique comes in handy. Hope this helps but everyone has their own opinion so try what's best for you, a'ight...
Old Apr 25, 2005 | 07:19 AM
Factory_Freak's Avatar
Spammer
That's good for 14's all day.
Old Apr 25, 2005 | 01:17 PM
Silver_S2000's Avatar
One way that I have found to get out of the dig with little to no bog is to rev it up to 6-6.5k hold the ebrake up so you can let out of the clutch slightly ( just to put some tension on the rear end...this means less "shock factor" less slippage and less damage on your diff) And whenever you drop the clutch you will see some spinnage all the way to 6k VTEC...and youre set...No bog...great jump off the line...Try it out..and dont forget to put tension on the diff.
~Cody~
