00 vs 03? Specific similarities/differences
Old Sep 22, 2004 | 11:42 PM
nik2000's Avatar
Default 00 vs 03? Specific similarities/differences
Greetings to all from sunny Greece!
I am an owner of a 00 and I would like to make some small modifications, since I have found some used parts from a 03 model. I would like to ask if some parts of the 03 fit to 00,
1. Does the door panels of the 03 (with the tweeters) fit to the 00?
2. Does the top of the 03 (with glass) fit to the 00?
3. Any idea where the water pump for the headlight is? (only european models have headlight washers, I think!) or any other possible/common reason for not working.. I have the service manual but nothing is mentioned about headlights washers!!
4. If I buy a hardtop for a 03 will it fit to the 00 with the proper installation kit or I should get a hardtop for the 00 from the beginning?
5. will the rear lights of the 03 (with the grill) fit to the 00?
thats all for now,
many thanks in advance
Nick
Old Sep 23, 2004 | 03:21 AM
ImportSport's Avatar
First please use the search function. These are all very common topics.
1.) yes
2.) only with modification, unless you swap the entire frame and motors. Do a search you should find a topic with instructions
3.)dont know
4.) all you need is the right install kit
5.) If you mean the lights with the chrome ring... yes they fit. Even '04 tail lights can work but require modification. There are instructions for this in a thread.
Best of luck with your mods!
Jasonoff
Jun 30, 2004 12:11 PM
Jasonoff
Jun 29, 2004 09:59 AM
jcp
Mar 22, 2003 11:29 PM
