100 Octane Fuel
Old Jul 11, 2003 | 01:00 PM
SJSHARKS's Avatar
Default 100 Octane Fuel
Has anyone used this stuff in their S2000 and had any performance gain?
In my area the highest octane I can buy is 91 octane. Tha owners manual calls for higher octane gas.
Is it possible to blend 100 octane fuel, in some ratio, into 91 octane fuel to increase the overall octane rating up to 92 or 93 octane?
Old Jul 11, 2003 | 01:17 PM
blues2k3's Avatar
I have actually used 100 octane unblended here in NYC we can pick it up at Sunomax. I use either this or 94 octane blended with booster regularly. There is a slight performance gain with the fuel that you can feel. Since my car is still NA the difference is not too much but I am certain with nitrous, SC or turbo it would be more noticeable. The price of 100 oct is about $4 per gallon in the off season and $4.5 during the summer months. 94 oct is at 1.85 per gallon.
Old Jul 11, 2003 | 01:21 PM
dundonr's Avatar
I've heard you can mix premium with Toluene to increase your octane rating. Toluene shouldn't hurt your engine, since a large majority of gasoline is toluene... Toluene has a octane rating of 114 by itself...
Old Jul 11, 2003 | 01:39 PM
Gabe's Avatar
Yep you can mix in toluene to raise the octane rating of gasoline without any major complications. However there is absolutely no reason to do this on the S2000. The ECU is programmed for 91 octane and using anything with a higher octane rating will have no affect on performance (unless you are boosted or running nos). The ECU compensates for parameters such as high temperature by retarding the ignition which is the only situation in which I could see higher octane gasoline being useful on a stock or slightly modified car. Since the ECU chooses to retard the timing based on temperature instead of detonation there would be no beneift to running higher octane fuel. IMHO you're just throwing away your money by purchasing higher octane fuel.
Octane rating is simply a rating of a fuels resistance to detonation, it is in no way shape or form a rating of the fuels power potential.
Gabe
Old Jul 11, 2003 | 01:50 PM
jjkt's Avatar
Just to be clear, Gabe, you believe the 93 octane recomendation of the Owner's Manual is in error, or at least overstating the case? I sure would like to use less expensive fuel in my s2000. Can anyone else back this up?
Old Jul 11, 2003 | 02:07 PM
RedY2KS2k's Avatar
[QUOTE]Originally posted by jjkt
[B]Just to be clear, Gabe, you believe the 93 octane recomendation of the Owner's Manual is in error, or at least overstating the case?
Old Jul 11, 2003 | 02:27 PM
Gabe's Avatar
Originally posted by RedY2KS2k
My owner's manual ('00) states, "Premium unleaded gasoline, pump octane number of 91 or higher." See the "Service Information Summary" facing the inside of the back cover.
My 03 states the same thing on page 120.
Gabe
Old Jul 11, 2003 | 02:41 PM
RedY2KS2k's Avatar
Gabe,
My '00 manual also says it on page 116, as well as the page facing the inside of the back cover. I guess I should have looked further.
Old Jul 11, 2003 | 02:44 PM
krazik's Avatar
Administrator
So long as you aren't detonating, the lower the octane, the more power you get from the fuel.
Higher octane is higher detonation resistance, not higher power.
Old Jul 11, 2003 | 03:23 PM
KennyS2K's Avatar
Make sure that it is un-leaded.
some wanting higher octanes use aviation gas.
av-gas is leaded and will ruin cat.
octane is not a power enhancer, slower burn for higher compressions to resist detonation
