100k maintenance/service?
Old May 20, 2009 | 11:16 PM
si2ik's Avatar
Default 100k maintenance/service?
I'm planning to buy a 2003 GPW with 100k for $10.5k. Price to high?
What kind of maintenance/services should be done at this point? Need some questions to ask the seller about what has been done.
Old May 21, 2009 | 05:30 AM
s2k aok's Avatar
sounds like a nice price, i'd change all the fluids though (oil, brakes, coolant, differential, transmission, wiper fluid*)...
Old May 21, 2009 | 09:26 AM
Kermdaddy's Avatar
Don't forget air and cabin filter.
Spark plugs are due at 105k. I'd do a compression test while I had the spark plugs out for good measure. Brakes could be an issue depending on when they were last changed.
Old May 21, 2009 | 09:27 AM
BEASTMODE's Avatar
I just had my 100k done. Flushed brakes/cutch fluid, oil/filter change, plugs. I did the trans and diff. @ 90k, so I didn't worry about those. It's a good time to just check everything else over too. Check the suspension for wear. Check valve clearance too.
Old May 21, 2009 | 11:15 AM
s2k dre's Avatar
Just make sure the motor doesnt smoke and adjust valves and change fluids and ur good to go.
Old May 21, 2009 | 05:13 PM
si2ik's Avatar
When do you think the clutch will need to be replaced?
Old May 21, 2009 | 05:18 PM
hotknives's Avatar
if there is smoke coming from the engine what does that mean?
Old May 22, 2009 | 06:27 AM
BEASTMODE's Avatar
When it wears out. It's really different for everyone. If it starts slipping really bad, it's probably time.
Old May 22, 2009 | 06:30 AM
BEASTMODE's Avatar
He means smoke coming from the exhaust, not the engine itself. Usually smoke is a sign of either worn piston rings or even a bad headgasket depending on the color of the smoke. I think we can all agree smoke means bad things when it comes to cars.
Old May 22, 2009 | 06:40 AM
Mike21's Avatar
white smoke: condensation if it's light and right after start-up. if it's continuous, it's coolant = you need a new headgasket.
bluish/gray: oil. piston rings or valve seals.
black/gray: fuel. you're running rich. change your plugs and possibly o2 sensor.
Cudajon
Jul 21, 2010 04:41 AM
Nabs 79
Jul 19, 2007 09:46 AM
Enusmith
19
Jun 29, 2007 11:43 AM
ktheppharaj
Jul 4, 2006 08:58 PM
wantone
Jul 17, 2003 09:32 PM
