18" Wheels/Tire combo for $3K or less?
Guys help me out here.
Finding a decent set of 18" wheels/tires that will properly fit AND stay within the $3K budget for the S2K is like trying to find a needle in a hay stack.
Very limited and few.
Here are my specs that I want:
- Front 18x7.5 offset ~55mm with 225-40-18 tires
- Rear 18x8.5 offset ~60mm with 255-35-18 tires
Does *ANY* wheel exist with those specifications and I want to stay within my budget of $3K or less (preferrably less) for both wheel and tire?
Damn, only if Honda made 17" wheels that came OEM with my S2K. ;-)
Thanks for you help!
Mark, the tough part is finding an 8.5" wheel with + 60mm offset for less than $500.
Maybe you could rephrase the question to get some leads;
"Anybody know of a 18x8.5" wheel with ~+60mm offset on a 5x114.3mm bolt pattern with hub diameter of ?? for less than $500?"
You find that bad boy and you're 90% there!
You can get a nice set of rims from Volkracing TE-37 in gunmetal,bronze or white with Toyo tires or Summmitomo in 18 inch for about 2800.00! I live out here in NY and the best prices out here in the East coast for high quality rims is Ultima,in Lynbrook. Or check their website http://www.ultimaperformance.com ask for Mike Rivera tell him Bob sent you
This is wat u want....exactly wat ur askin for.....
just under $3000 with top of the line T1s tires....
Three most important things trust me....
it has to be light....
it has to be strong.....
and it has to be one piece...
Originally posted by AusS2000
If you'd settle for 17" then look at thr ROH Adrenalin. I negotiated with (read: bullied) ROH to make sets with the correct offsets for the S2000 and am arranging a Group Buy as we speak. The wheels will be under $1000 (yes, I'm not kidding) so you should get through the entire ordeal for $1800-$2000.
AusS2000....
This sounds pretty interesting...Where can get more info on these wheels.
I'd be very interested...
FK
Wayne
