Are 19" rims too big?
Old Oct 8, 2001 | 08:58 PM
R-nel's Avatar
I was looking into purchasing 19" Leon Hardiritt Kloster rims for my car. The specs are as follows:
Front:
19X8 40mm offset with 235/35/19 toyo tires
Rear:
19X9 50mm offset with 265/30/19 toyo tires
I'm not planning on lowering my car so for all you "Offset GURU's", will this setup work without rubbing or any other problems???
Old Oct 8, 2001 | 09:20 PM
TommyAmrani's Avatar
i might be wrong... but i think you can mainly go up 2 inches in size from stock... but THREE... that's pushin' it...
you might have some fender rolling to do... NOT SURE THOUGH...
ANY EXPERTS OUT THERE?
Old Oct 8, 2001 | 09:44 PM
RT's Avatar
RT
no expert, but those fronts are going to be rubbing by a good 1/2" and the rears will rub by no less than 1/4" with those tires.
Don't do it MAN!
19's are cool, just not in those offsets/widths
Old Oct 8, 2001 | 10:39 PM
S2R's Avatar
S2R
I think big rims look good, but those offsets won't fit right.
Old Oct 9, 2001 | 02:54 AM
xtc@9k's Avatar
I think that 17's are as big as you want to go on a S2000.
Old Oct 9, 2001 | 04:09 AM
jschmidt's Avatar
Yea, by about two inches, unless its a trailer queen.
Old Oct 9, 2001 | 08:58 AM
tantheman's Avatar
18" Volk GT-N with Eibach Pro Sports no rubbing at all.
Tan
Old Oct 9, 2001 | 08:55 PM
UltimaMR's Avatar
Although everyone has their own opinions or beliefs, let me share our experience with 19's:
Our yellow car has been driven to all the shows we have attended this year. The 40mm offest front setup has not rubbed and bear in mind, we are running a 7mm spacer to clear the Brembo big brakes. This in turn brings the offset to 33mm on an aggressively lowered car.
The rear 50mm offset wheels does require modification to the fender well. We are running a very aggressive tire size, 265/30/19, and after the modifications have experienced no rubbing whatsoever.
We have done 18X10 Kinesis wheels on a silver S2000 with 285/30/18 tires with the same fender modifications with no problems.
Although there is plenty of speculation out there, we have experimented with a lot of different rim/tire combos and know what works and what doesnt.
Both cars had custom ordered wheels with offsets that we specified.
For those that want to see in person, the yellow car will be at Fall Colors.
Hope to meet you guys there!
Old Oct 9, 2001 | 10:53 PM
RT's Avatar
RT
33mm?
What width rim?
What size tire?
How much negative camber?
How much crack? j/k
Old Oct 9, 2001 | 11:19 PM
tze's Avatar
tze
The bigger you go; the slower you go
