1st gear clunk
I used the search option and still counldn't find an answer. But I did notice some owners have this problem and some don't.
MY04 makes clunking sound everytime I put my car in 1st gear. I hold the clutch down and put it in first and it makes that clunk sound...But if I hold the clutch down for a while before I put it in 1st gear...it doesn't. It's really weird. I drove a different S and it didn't make any clunk sound.
I also noticed the same issue with the rx8 when I test drove one. I drove it 3 times, each time at a different dealership. Out of the 3 rx8's I drove, one particular rx8 made that clunk sound when I put it in first gear.
Does anyone know why it's doing that...??? I would really appreciate it. Thanks.
This was explained indepth sone time ago by "woodwork" who is a engineer for Honda in California.
Here's a simplified version.
He says that if you sit at a light with the clutch out an in neutral, the transmission spins at the same speed as the engine.
If you depress the clutch and try to move it into gear too fast, without giving the transmission time to spin down, you get a 'clunk' which is just the built-in drivetrain looseness being taken up abruptly as everything 'connects'.
The cure is when you depress the clutch, give it at least 2 seconds for the tranny to spin down and the clunk will be gone.
Regards,
BD
Regards,
BD
Regards,
BD
Regards,
BD
ya, that was it.... I knew I was close
sorta...
I have the clunk as well. Also, when the car is 'cold' 1st gear is sometimes difficult to engage. Most symptoms disappear as soon as the car warms up. It doesn't really bother me that much anymore. Seems like a very common problem.
