2 questions
Old Apr 1, 2006 | 08:36 AM
passmans2kny's Avatar
Default 2 questions
how much does the stock flywheel weigh? and does someone make a 3 inch test pipe, i think the nvidia and jic pipes are 2.5 inch, i dont want a bottle neck
Old Apr 1, 2006 | 08:50 AM
S2kracka's Avatar
*edit, double post*
Old Apr 1, 2006 | 08:51 AM
S2kracka's Avatar
You'll have to have a testpipe custom fabbed if you want 3". I assume you must be turbo or going turbo? In that case, I don't even think the downpipes that come in the kits are made to bolt up to the factory stuff so you'll need a custom exhaust anyway.
Old Apr 1, 2006 | 09:09 AM
really the lovefab doesnt bolt up to stock exhausts, dam i wanted to use my apexi gt spec, i love that exhaust
Old Apr 1, 2006 | 09:12 AM
S2kracka's Avatar
Your Apexi exhaust isn't 3" anyway.
Old Apr 1, 2006 | 09:17 AM
esoteric's Avatar
What he said.
I believe for the S it is 60mm...
Some GTspec are 95mm, but not the S...
Old Apr 1, 2006 | 10:12 AM
xviper's Avatar
2 questions
Please make your title more descriptive so future searches will be more useful.
Old Apr 1, 2006 | 10:43 AM
S2kracka's Avatar
Correct, that is 2.36" which is the same diameter as stock piping between the cat and split.
Old Apr 1, 2006 | 03:13 PM
XclusiveAutosports's Avatar
I'm assuming that you are going with a Lovefab turbo kit? In that case, just ask Cody to make you a 3" testpipe and your problems are solved. Also, that is news to me if invidia makes a testpipe, I didn't think they made one, but in any case why not go with a lovefab testpipe also? I believe that the stock flywheel weighs about 14lbs.
Old Apr 1, 2006 | 03:19 PM
[AP2-2NV]'s Avatar
http://www.ultimate-racing.com/Products2/S...K_Exhaust.shtml
