3" single Exhaust on NA?
Hello all,
I was wondering if 3" cat-back exhaust would hurt/help performance on an NA s2000.I would be running this off of a 63mm test pipe. I am building another FI motor to be installed late winter. I will be running a full 3in exhuast for that so i was wondering if this would be a good start. The car is being driven now and don't want to do anything to effect that. I wanted to know if there is the proper amount of back pressure with a 63mm test pipe and 76mm exhaust. i have read that 70mm exhaust is great for an NA, so does 76mm work as well?
thanks
matt
thanks
matt
hmm... i only found one other thread that adresses this and i'm gathering that 70mm is as big as i should go on a NA application....
just didn't know if the stock header to test pipe to 3 inch would work. i'm guessing no.
yeah thats what i'm gathering. I'm just getting all my extra turbo parts together. Just thought if i could use this then more modivation to get it now.... I guess i'll just wait and have it made when the turbo is on.
What I've always heard was that 63 gives more lower end power while 70mm gives higher end power. Being confused that I was, I started a myth busting thread. In the end, someone showed dyno graph of 63mm and 70mm back to back from AJR, and 70mm gained more power than 63mm at all powerband.
https://www.s2ki.com/forums/index.ph...ic=563243&st=0
Have a read if you're interested.
liquid_helix136
Oct 19, 2009 11:18 PM
cougar hunter
Sep 8, 2008 01:26 PM
mustangkiller01
Aug 9, 2008 04:26 PM
