3M Clear Bra / Under Door Template
Old Apr 9, 2010 | 08:52 AM
Mocky's Avatar
Default 3M Clear Bra / Under Door Template
Apparently this was on the site at one point but I've tried searching for it and have had 0 success finding it.
I'm trying to find a template of the piece of clear bra / stongard that goes under the door handle. On my berlina, I had a ton of scratches under there so I'd like to place a few strips underneath the door handle to protect it. I could just free-form it but someone had mentioned that a template was on the site at one point... I just can't find it.
Any help would be great..
Old Apr 9, 2010 | 09:16 AM
sam_spider's Avatar
Site Moderator
Community Influencer
I can't find it either.
Old Apr 9, 2010 | 09:20 AM
rossco's Avatar
just wear racing gloves when you drive nah jk, maybe just make your own template with paper something thin so you could use a lead pencil or something to lightly trace the shape. should be able to make it close the shape enough that it will protect from scratches.
Old Apr 9, 2010 | 09:53 AM
Mocky's Avatar
It's actually not so bad on the drivers side.. it's the passenger side that took the brunt of it....
I can do it on my own but was thinking there was something out there already just to use that..
Old Apr 16, 2010 | 06:08 AM
Mocky's Avatar
I made some last night.. It's basically a rectangle.. lol.. I think I'm going to make a dozen or so sets since I have a roll of 3m..
Old Apr 16, 2010 | 06:31 AM
Vanishing Point's Avatar
I've used this method numerous times with good success, take a piece of clingy "Saran" wrap and lay into area you wish to make a template. Then take a felt tip pen and either dot the outline of the shape or trace it, your choice. I then peel the wrap and transfer it to the 3M material. The dot method works better in tight/confined areas where tracing is near impossible.
Hope this helps.
Old Apr 16, 2010 | 06:59 AM
Mocky's Avatar
now THAT is some good advice..
Thank you!!!!
Old Apr 16, 2010 | 07:10 AM
Your very welcome, if you have trouble fitting the material in tightly enough use a light dose of a hairdryer to shrink it into position.
Old Apr 16, 2010 | 11:08 AM
termigni's Avatar
what's better is to use painter's tape, trace with pen and peel that bad boy right off and use it as template.
eric
155
Jun 19, 2009 05:30 AM
NoRawkus305
Aug 15, 2007 08:48 PM
S2KMark
Feb 15, 2007 06:19 PM
paS2K
Jun 21, 2005 06:39 PM
NECurve
Nov 11, 2004 04:58 PM
