4.77's installed
Old Sep 10, 2003 | 06:02 PM
Gr8nbed11's Avatar
Default 4.77's installed
I just got my car back with the 4.77's from ricks installed today. I'm anxious to see what they can do but I have to take it easy for a couple hundred miles to break 'em in. Intall was $360 and took 2 days.
Old Sep 11, 2003 | 09:51 AM
Hockey's Avatar
Please post when you have formed an opinion.
I am considering the gear change, but researching ratio choices and advantages.
Thanx,
Hockey
Old Sep 11, 2003 | 10:04 AM
Pakisho's Avatar
Im thinking of doing the same: exhaust oversize throttle body, tune it with a vafc, and get a light flywheel, clutch, the comptech diff reinforcement, and 4.44s.
Now, where to begin.
Old Sep 11, 2003 | 11:04 AM
EVAN_In_A_SPA's Avatar
Nice.. I hope it goes well after the break-in.
Old Sep 11, 2003 | 04:40 PM
Gr8nbed11's Avatar
[QUOTE]Originally posted by Pakisho
[B]Im thinking of doing the same: exhaust oversize throttle body, tune it with a vafc, and get a light flywheel, clutch, the comptech diff reinforcement, and 4.44s.
Old Sep 11, 2003 | 05:22 PM
trich1687's Avatar
I have had the 4:77s for a week , Finally put 800 miles on them for break in (under 65mph) ( I drive 150 miles a day back and forth to work) the S usually doesn't do this journey as it's all Highway and only a few miles of back road. Tonight I got on it and broke the tires loose from a launch, then caught second pretty hard. It's a blast. As for the higher revs, I was at 80 on the highway in 6th @ 5200 RPM. Still not bad. You really blast thru the gears and are in 4th before you know it. I can also roll thru stop signs in 2nd , no lugging. The yellow box is also an easy install and it corrects any Spedo & Odometer error. It was off 18% with bald 16" 02s Great mod overall.
Old Sep 11, 2003 | 09:36 PM
tenblade2001's Avatar
Hockey, I just had the 4.44 installed and after the break in, I'll PM you with my impressions if you'd like.
Old Sep 12, 2003 | 12:43 PM
Gr8nbed11's Avatar
What is the Odometer error all about? When my yellow box gets installed it won't correct it from when the gears were installed, will it? Do you have directions on how to install and calibrate it?
Old Sep 12, 2003 | 01:22 PM
xviper's Avatar
[QUOTE]Originally posted by Gr8nbed11
[B]
Old Sep 12, 2003 | 04:24 PM
JULESXL's Avatar
