457-R gears installed
Old Feb 28, 2006 | 04:19 PM
StarvinMarvin's Avatar
Default 457-R gears installed
Just installed the CT 357-R final gear, no instructions came with the gears regarding the 3 heat cycles. Looked at the gear forum but found nothing. Please tell me the details, is it ok to do the 3 cycles on three different days? I don't drive the car often. And I understand not to push it until after 500 miles. Thanks.
Old Feb 28, 2006 | 05:06 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
You mean 4.57???
Old Feb 28, 2006 | 05:30 PM
2QYK4U's Avatar
It is on their website.
1. Drive "normal" for 10 minutes...let cool-down for 2-3 minutes. Repeat 2-3 times.
2. Drive "normal" for first 500 miles.
3. Replace diff fluid after 500 miles.
Old Feb 28, 2006 | 07:30 PM
Foo Cat's Avatar
The post above was incorrect as you are suppose to drive the car "normal street driving speed" for 10 MILES and stop and let it cool down for 30 minutes. This would be considered one cycle. You are suppose to do this 2 to 3 times. Richmond has a website that has the instructions for break in.
Old Feb 28, 2006 | 08:08 PM
Thanks guys, yes - I meant 457-R. Must have been a "senior moment".
(I use to be indecisive - now I'am not so sure)
Old Feb 28, 2006 | 09:02 PM
2QYK4U's Avatar
Read Jeff's post...2nd page...half way down...
https://www.s2ki.com/forums/index.ph...c=352088&st=25
Old Mar 1, 2006 | 06:18 AM
Wisconsin S2k's Avatar
[QUOTE=2QYK4U,Feb 28 2006, 08:30 PM] It is on their website.
1.
Old Mar 1, 2006 | 06:20 AM
the dumontster's Avatar
And then you can beat on them?
Old Mar 1, 2006 | 06:21 AM
This is what his post says:
Street vehicles should be driven at normal street driving speed for approximately 10 miles, then stop and let cool for minutes. Do this 2 to 3 times.
notice that via a typo, he left out the "30" before the minutes part.
no you should allow for a non-beating breakin for a couple hundred miles. this isn't required, but as a safety precaution, it can't hurt.
