5w20
Old Aug 26, 2003 | 05:04 PM
gtirs's Avatar
Default 5w20
Why would a Honda dealer recomment 5w20 vs. 10w30 motor oil called for in the s2k manual? Is it safe to use?
Old Aug 26, 2003 | 05:08 PM
jguerdat's Avatar
I wouldn't use it. I want the extra viscosity for high RPM work...
Old Aug 26, 2003 | 05:13 PM
RazorV3's Avatar
b/c the people at your dealership are idiots, only use 10w30
Old Aug 26, 2003 | 05:16 PM
gtirs's Avatar
If you want less resistance and more lubricant the 5w20 would make sense, wouldn't it?
Old Aug 26, 2003 | 05:17 PM
RazorV3's Avatar
5w20 is thinner i believe, you want a thicker substance that doesnt break down as easily as the thinner oils do(especially during high rpm driving)
Old Aug 26, 2003 | 05:20 PM
gtirs's Avatar
Thanks for the input!
Old Aug 26, 2003 | 05:22 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
It would be o.k.if you drive in a very cold climate.
Old Aug 26, 2003 | 07:00 PM
Austblue's Avatar
I thought that if you were in a colder you would still use 5w30? instead of 10w 20 that is.
Old Aug 26, 2003 | 08:21 PM
TrueDrezzer's Avatar
10W-30 normal temps down to -20'C
5W-40 for temps below that
straight from the (EU) manual.
Not that we can buy 10W-30 here, so $tealers spec 10W-40.
5W-20 probably isn't ideal, but could work depending on the situation. Isn't that the recommened stuff for Pilots?
///Robin
s2000guy's Avatar
You are correct. All newer hondas use 5w20 so they assume the s2000 uses the same oil.
